Futaba 2.4GHz
#196
Hey Adam did you run your system in hrs mode?
one of my friends has one and he has had shut down problems. he runs a futaba 9560 servo a Q2 and a personal trans. he also has the new 3pks. his brother has the same running gear but the older 3pk and has no problems in hrs mode.
#197
I've been running mine for ~2 weeks in a 3PK Super, HRS mode, Airtronics Servo, Novak GTX. No shutdowns, glitches, twitches, etc. Very happy with the system so far...
Denney
Denney
#198
6 cell right because I'm talking about 4 cell 19t oval
#200
yes his works fine in ppm mode.
Adam which radio are you using? the silver 3pk or the new black 3pks. because his brother uses the older silver 3pk in hrs mode works perfect. and he has the new black 3pks has to use ppm mode
#202
I've only used it in 6-cell so far. At least one other at our track is using HRS in 4-cell 12th scale on-road.
#203
Has anyone used this system in 4 cell - 12th scale without a receiver pack? Any issues with not using the receiver pack?
#204
No problems at all.
#205
Is this available anywhere in the US right now? Does it have an antenna wire or not? I have seen pictures of it both ways.
Thanks.
Thanks.
#207
Originally Posted by rc-zombies
it's been available for almost 2 months now. and yes..it does have a short external antenna wire.
Also, Ive noticed that the few US stores I do order from don't have it in stock - do you know of anywhere it is available to buy (anywhere in the world) right now??
thanks.
#208
2.4 withour rc pack
Had to run mine without rcv pack with out any issues last weekend.
antenna wire bought mine in the Uk it has no antenna wire have been trying to find out the difference will post when I find out the reason.
#210
are the modules and receivers available only in the U.S. cant seem to find it with other on line hobby shops
