Like Tree1Likes
  • 1 Post By belewis01
Old 08-29-2017, 12:06 AM   #1
Default Body mount questions
So a general question for body mounting such as a touring car, or a pan car ...
Is it better to allow the body to float a bit, or should it be held on to prevent it from moving?
I generally make the mounting holes slightly oversize, and clip the body mount pin so the body can float up a millimeter or so. My thinking was to isolate any potential body twist from the chassis.
Last race someone suggested I use the foam body mount rings and pin the body tighter against the mounts ....... as that someone is much faster than me I thought it worthwhile to investigate
Thanks,
Bruce
belewis01 is offline   Reply With Quote
Old 08-29-2017, 03:20 AM   #2
I let it float a little to eliminate the body affecting the chassis twist/tweak
I used to use foam body mounts too but then got rid of them cos the slightly loose nature of the body was lost and also any downforce generated by the body would be compressed in to the foam rather than into the chassis
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 08-29-2017, 04:01 PM   #3
WheelNut's Avatar
Send a message via MSN to WheelNut
The downforce the body is generating is not lost through the foam. All that force is still translated into the chassis. The foam cushions the body, but that just means that the area through which the body translate force to the chassis is spread out over a larger area. Some tiny amount of energy would be lost to heat from the internal friction of the foam, but that amount would be very small. Imagine if you were lying on the couch and a kid throws a large pillow on top of you and then proceeds to jump on top of the pillow. The weight (force) of that kid is still squashing you, but its over a larger surface area.
To answer the OP: I would recommend over sizing your body post holes by 1-2mm so that the body doesn't affect the chassis flexing and try to position your clips, posts, supports so that there is 1-2mm of vertical play as well. Less chance of tweak and it will let the body move around a bit if it starts to rub on the track.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 08-29-2017, 08:58 PM   #4
Thanks guys, seems we are of the same thinking - slightly loose mounting to prevent the body from tweaking the chassis.
tbrymer likes this.
Losi XXX-SCT Thread MajorPede Electric Off-Road 9577 10-03-2017 02:58 PM
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-21-2015 12:54 AM
Body Mount Question javi0sh Rookie Zone 7 08-28-2013 09:20 PM
Timezone Raceway Park MAD916 Northwest Racers 1296 04-09-2013 10:38 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
