Old 08-05-2017, 04:08 AM   #1
Default Tamiya F104W Grinding Noise
Hi All,
Took my RC car for a spin today and noticed a grinding noise coming from the rear of the car. Took the diff apart, re greased it, reassembled the pinion and spur and took the rear axle off and reassembled it, however the problem is still there. I have attached a video of the problem. Any help would be greatly appreciated
Link https://youtu.be/olIqtAB8cqw
Cheers,
Chris
Chris_McLarenF1 is offline   Reply With Quote
Old 08-05-2017, 04:18 AM   #2
1/8 IC Fan's Avatar
Trader Rating: 44 (100%+)
check for small rocks in your spur gear. Also given that you are running a silver can 540, sounds like the motor is giving off chatter too.
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 08-05-2017, 04:38 AM   #3
Is your spur gear stripped? Even if one tooth is damaged that could be the source of the noise.
astgerma52sp is offline   Reply With Quote
Old 08-05-2017, 05:13 AM   #4
Ph3nyx's Avatar
it seems that your gear backslash is too tight , try to loosen it a bit.
check also the pinion , tamiya's pinion are very soft , the tooth can "twist".
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 08-05-2017, 12:09 PM   #5
Oil the bushings on the motor. The screeching noise is a dry bushing in the 540 motor.
Serzoni is offline   Reply With Quote
Old 08-05-2017, 01:35 PM   #6
You have 2 issues going on. First your gears...it sounds like either something is caught in the teeth or something was and damaged the teeth. Go over both gears closely and pick out anything you find in the teeth and use an exacto knife or file to smoothen out any damaged parts as much as possible. Also check your gear mesh. When the gear mesh is set properly you should be able to feel a slight amount of play between the spur and pinion. The 2nd issue you have is dry bushings in the motor. Get a light bushing oil and put 1 drop on each. Give them time to soak in, spin the motor by hand a bit so that it coats well then wipe off any excess so it doesn't attract dirt.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
