Everything needed On Road Racing Car $2000
I need advice. I want the best setup for $2000 dollars. I have nothing
If I could start over agian I would make sure to buy all the good stuff at first, so you only spend the money once!
Good Charger (100+)
Good Discharger (Not a Dead Short, something like a Novak Smart-Tray) (80)
Good Power Supply
Battery Cooling Fan (not needed, but are nice)
Setup Station w/ Droop and Ride Height gauges
Good Cells (At least 2+ Packs)
Set of good Tools
Good box/tackle boxes to store it all in
Then worry about the car, look for a used one.
Good Charger (100+)
Good Power Supply
Set of good Tools
I'll tell you what I have now
RDX US Spec-450
M11-300
Spektrum-150
Novak GTX-150
Hitec 925 MG Servo-80
Integy discharger-80?? (have to check on that)
Corally Battery and Motor Case-60
1-5 motors-40 (one) 200 (five)
five 3800 batteries at most 100 (500)
add all that up thats about 1970. however thats with five batteries and motors, for a start you wont need that...but all that stuff i listed is top of the line equipment
hope that helped
RDX US Spec-450
M11-300
Spektrum-150
Novak GTX-150
hope that helped
Good setup would be:
Xray T2, MSX, Cyclone (not in order) = $400
3PK or Helios = $280
Novak GTX = $150.00
Futaba S9451 Servo =$80.00
Spektrum for radio =$150.00
Duratrax Ice Charger = $120.00
Generic Power Supply = $50.00
Teamwave Tray Discharger = $100.00
Hudy All in one = $280.00
Team Cobra lathe = $150.00
You have $240.00 left to spend on tools, motors, batteries & tires. Also if you buy in 1 place you can get big discounts.
Novak GTX = $150.00
Team EAM
Car
T2 or RDX 400-450.00
*Ko Helios or M11 300.00
Duratrax Ice charger 120.00
*High speed servo 100.00
Competition electronic's or Radio shack power supply 100.00
*Speed control (Novak, Tekin, KO) 140-180.00
Batteries 45-70.00 each x 6 (You dont need the best if you are starting off)
*Associated, Integy or Hudy tools 50-150.00
Much More Discharger 200.00 or Novak Smart tray 80.00(this will keep your batteries like new)
This equals 1870.00 using the highest prices listed. The rest I would use to buy parts for the car. The items with an * beside them are items you do NOT want to buy cheap now and upgrade later. Dont bother with a spectrum unit right now. Its a luxury that still has its problems and with everyone else using it it's very easy to get your channel when you need it.
EA
EA
Suspended
He is going to need some tires also....
good car $400
lrp comp 2 charger $169
lrp power supply $119
2 smc 3800 packs $140
rp 30 tires $40
motor $40
spektrum all in one radio $199 comes with servos
ko servo $119
speed contro hara twister or gtx $150
soldering station csi $39.95 mail order wholesale(ne one can do it)
integy 0-30 discharge $59
pinions various sizes $25
battery bars and solder $20
lathe with diamond bit cobra $199 use motor run feature on lrp charger to run it.
car stand $15much more battery cooler $59
much more motor cooler $90
body and paint $30
don't forget about tax if you got it
rp 30 tires $40
motor $40
ko servo $119
body and paint $30
Don't forget to include "Rctech Subscription". Worth every penny
I like these type of posts because after spending so much on this hobby I feel I can offer something from learned mistakes...
XRay T2 - $400
LRP Quantum 2 ESC - $150
M11 Radio - $250
Spektrum for M11 & Receiver - $150
Airtronics 94360Z Servo - $110
ICE Charger with Temp Gauge - $130
Pyramid PSV 200 Power Supply - $60
Hakko 936 Soldering Iron - $80
Much More CTX D Discharger - $200
Team Associated Nut Drivers - $45
Team Associated Hex Drivers - $45
3 Packs 1.20+ IB3800's Pre-Built Fusion Batteries - $200
2 Stock Motors (Monster & C027) - $80
Team Magic Formula 8 Hauler - $200
12v Power Distribution Box - $35
Tires - $40
Integy Set Up Station 2 - $100
I went a little over your $2000 budget but you would be VERY happy with this set up. There are still a few things missing with you will eventually need with a tire truer and comm lathe the 2 biggest items but most hobby shops offer those type of services. I also overlooked small items like CA glue, pinions, solder, etc. Good pinions will run around $5 each and the rest of the misc parts I mentioned can be had for about $20 total. Good luck!
XRay T2 - $400
M11 Radio - $250
Tires - $40
pretty interesting topic, if i could do it all over again i would buy all the top stuff first and you prob save some $$$ in the long run
Car-T2-------------------------400$
BMI Chasis for T2---------------125$ (est)
Radio KO Helios-----------------275$
Spektrum for KO----------------150$
KO Servo 2343------------------110$
Esc. Novak GTX/tekin g11 pro----150$
motor---------------------------40$
tires----------------------------40$
batts 4 race packs---------------250$
batts 2-3 practice packs---------150$
hudy set-up station--------------300$
Chargers
1-Turbo 35 gfx-------------------400$
1-LRP 2- ------------------------170$
CE 23 amp power supply ---------125$
Carry Bag -----------------------50$
Table & Chair --------------------50$
Fantom lathe --------------------400$
EZ tent -------------------------150$
tools-----------------------------100$
Total 3400$$$
hearing your buddies in the pit say "MY SAC" every other word out of his mouth and on the drivers stand " I THINK JAY JUST SHAT HIMSELF!!!"
PRICELESS . . .
i know i know i couldnt help it
and i only shot your budget by only 1400 bucks
LATE
Chargers
Total 3400$$$
PRICELESS . . .
LATE
Cyclone,msx,T2,RDX,BD-400
setup station-200 hudy,Integy what ever you like the look at
chargers (2)-400 muchmore cell master or orion advantage
Equalizing board (2)-100 muchmore
Batteries-3 matched, and 2 cheepies-300
Motors (1) - 60
Lathe (1)-150
Tires (3) - 100 take off premounted are good 27's,32's and 22's
Tools - 100 Hudy or trinity or dynamite or integy what ever you want
Radio-220 3PK or helios are about 220 now so that is good
and the rest for accesories (if there is any left over)
forgot esc, oh well under 2000 is qutie a budget
What class to you want to run?
Motors (1) - 60
Lathe (1)-150
