bearing maintainence
Hey
i was wondering how you guys clean your bearings .. ive tried using RP7 and motor spray but still havent cleaned them...
they come from an X-Ray t1 and are sealed
any suggestions?
any suggestions?
I take the sheilds of both sides of the bearings, spray out the bearing with motor spray, and put a very small drop of trinity royal oil in the bearing. If a bearing is in a hub or any other sheilded area I leave that shield off, it really helps loosen the drivetrain, although it does take lots of maintainance. (I clean them after every raceday)
Thanx for your advice ...
not you mr4tc... y post when u live upstairs?? ...retard =)
I take the shields off and put them in a small small paint jar half filled with turpentine. Then I close the lock and shake well. Lubricate and install shields. Works for me.
Originally posted by Mr4tc
use kero dick head
use kero dick head
As for cleaning bearings. I normally remove from the car and soak in thinners and use an ultrasonic cleaner. Let them dry out (use a hair dryer if you want to do it quickly)...then a few drops of Trinity Royal oil. Sometimes you may to soak it a couple of times........
" I normally remove from the car and soak in thinners and use an ultrasonic cleaner."
That's not fair anymore... far to easy and efficient. Ultrasonic cleaners are excellent for armatures as well. Any place selling budget UC-cleaners?
Bearing maintenance
RPM & Robinson Racing make bearing "Blasters" that hold 1 bearing inside so you can spray out with cleaner and relube.
They work like a full size bearing packer and "SEAL" the bearing in a cone like device so the cleaner will be forced past the shields/seals. They work really well and much less work than removing the seals/shields.
An Ultrasonic cleaner would probally be the best. You could do all of the bearings at once and leave it unattended to go work on something else while they are cleaning. (I like that idea)
OK, now for my question.
Who makes a REAL Ultrasonic cleaner for a decent price and will allow you to use solvent based cleaners inside. (not water based only)
Thanks,
Thanks,
I take off the seals and take put every bearing in a motor tube or a baggy and let them soak all day then i let it all drain out and do it all over agian. The most I have done is 3 times then put a little trinty oil on them. Oh I use motor spray or a heave duty car engine degresre. Any thing that take the greese out will work so you can put your own in.
So... what's considered a real ultrasonic cleaner...? I'm guessing the one offered by Integy is not one?
What's the best way to remove my metal shields? I really have no idea what to do with them and how to pop them out.
Thanks!
Thanks!
does anybody use zippo lighter fluid as both a degreaser and a lubricant? i don't, but i've heard that's an easy way to get speed, and that way you don't have multiple chemicals involved in the process. just curious.
The Integy bearing cleaner tray is definitely not an ultrasonic cleaner. It has a small vibrate motor that rattles the bearings around in the tray. It works surprisingly well. I just spray enough motor spray in the tray to immerse the bearings and flip the switch, wait 10 minutes and the bearings are nice and clean. I use Niftech's light bearing oil but a lot of guys use Mobil1 and swear by it.
ohh yea ....... mobil 1 rules.... but make sure u really use the mobil one oil not some other 1/2 crap engine oil
