Like Tree9Likes
Old 07-09-2017, 08:29 AM   #1
Default Lube the drive belts
Hey guys,i wanne know if i can drop my belts in a bottle with some silecone spray.the reason is on outdoor tracks my belts getting really dirty with rubber and some times it also is on my diff.i wanne ask what i can do so that the rubber can find no grip to stuck on the diff and belts ..thanks
Ruudned is offline   Reply With Quote
Old 07-09-2017, 11:06 AM   #2
Tom1977's Avatar
Never ever clean your belt with silicone spray, WD40 etc.!
Your belt will skip under load. Use warm water and some soap to clean. For diffs and pulleys too. And dry them completely.
Tom1977 is online now   Reply With Quote
Old 07-09-2017, 11:45 AM   #3
Well that explains why my XXX-S incinerated a belt in 2 minutes. It stripped off every single tooth.
HPI-Racing|Team Traxxas|Team Tekin|Spektrum|Jr Racing|Jconcepts|Thunder Power|SPC-Racing
Blitz ESE|Traxxas SRT|Traxxas TCP|Rs Pro 7.5t|DX3C|Z9100s|TP-610C|
World Class Champion's runs World Class Equipment...Go Tekin or go home!
rc10t3b4 is offline   Reply With Quote
Old 07-14-2017, 02:51 AM   #4
Skiddins's Avatar
Years back we used to soak the belts in WD40 overnight to soften them. Though they were dried out before fitting them.
Obviously that isn't quite the same as trying to lubricate them whilst running them.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-14-2017, 06:43 AM   #5
dan_vector's Avatar
Trader Rating: 27 (100%+)
I use the silicone belt lubricant from BrilliantRC fantastic stuff and really makes a difference to the transmission and the belt never skips. We used to soak belts in WD40 years ago like the above poster.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 07-14-2017, 09:39 AM   #6
I have used full synthetic motor oil to lube all belts since the HPI Micro RS4 days. A racer discovered that the lubrication greatly increased speed due to reducing the belt friction from rubbing on the chassis. But when I tried it I noticed that the pulleys NEVER EVER get clogged with junk when racing on carpet which was also a major problem on the car with our surface. Since then I've lubed every single touring car belt and have not needed to clean a pulley in well over a decade. Never had any issues with the belt skipping even at low tensions. Never had to replace a belt due to wear either.
dan_vector likes this.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is offline   Reply With Quote
Old 07-14-2017, 10:08 AM   #7
Trader Rating: 45 (100%+)
Tire sauce on the non gear facing side.
Pro-Line/Protoform, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is online now   Reply With Quote
Old 07-14-2017, 10:13 AM   #8
RobS's Avatar
Interesting.. I remember doing it all the time back in the micro days but never really gave it a thought when it came to Touring Cars. Might have to try that out.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 07-14-2017, 11:31 AM   #9
A nice thing about full synthetic engine oil is that it's very tidy. It just vanishes or over time - no icky mess left behind. Nothing sticks. It's very different from all the typical lubricants and fluids we use on R/C cars.
Old 07-14-2017, 12:24 PM   #10
Are you soaking the belt in the oil, how are you applying it to the belt?
Brandon Smith
fanfor18 is offline   Reply With Quote
Old 07-14-2017, 01:28 PM   #11
JatoTheRipper's Avatar
What brand of synthetic oil are you using? I've seen sticky sythetic oil and the components are not going to evaporate so I'm curious about this.
Leaf Spring Mafia - Member #1
https://www.shapeways.com/shops/leafspringmafia
https://www.facebook.com/LeafSpringMafia
https://www.instagram.com/LeafSpringMafia
JatoTheRipper is offline   Reply With Quote
Old 07-14-2017, 02:10 PM   #12
Lone Drifter's Avatar
The Only cars I have had where the belt have Shredded were belts that have gotten lube on them and were Totally enclosed in the Chassis ( Losi XX4 4wd buggy and Losi Street Weapon touring car)
USVTA , USGT and Wheeler Fan
TC7, TC6, T3 11 & 12, and TLR 22-4
Looking Forward to New Racing Options
Lone Drifter is offline   Reply With Quote
Old 07-15-2017, 01:25 AM   #13
Regional Moderator
disaster999's Avatar
Brilliant RC Belt Silicone Oil
JatoTheRipper and dan_vector like this.
disaster999 is offline   Reply With Quote
Old 07-15-2017, 06:27 AM   #14
Trader Rating: 32 (100%+)
About Brilliant RC Belt Silicon oil,
how often you lube the belt??? every race??
hobbs is offline   Reply With Quote
Old 07-15-2017, 07:10 AM   #15
dan_vector's Avatar
Everytime I rebuild the car I will clean the belts with an old tooth brush and then reapply the belt silicone and allow it to 'dry' then put the belt back in the car. When the belt is new I will apply the silicone a few times and allow it to soak right into the belt before putting it in the car...
JatoTheRipper and mikeygar like this.
Tamiya Ta06 KREATOR1 Electric On-Road 2597 04-21-2017 01:11 PM
Capricorn LAB C801 1/8 scale DS Motorsport Nitro On-Road 1010 06-09-2016 09:42 AM
NIP Team Losi JRX-S, XXX-S, Type R parts Kraig R/C Items: For Sale/Trade 9 06-23-2007 10:38 AM
freeing up belt drive cars soto Electric On-Road 32 12-24-2004 04:57 PM
