Tamiya M-07 Concept
#467
Hi.
I have the problem, that i can't setup front toe out. The Kit standard ball cups are so long,that it is impossible to adjust toe out.
Can you recommend any other Tamiya parts,to solve this problem?
Greetings from Germany
#469
You can use Tamiya 54247 18mm Turnbuckle shafts and Tamiya54489 low friction 5mm ball adjusters
#470
#471
i run on black crc carpet
on the old grey carpet with my m05 i was running m-grip with the side glued with sauce without problem
but on black carpet the m07 is rollover crazy with the same tire setup and without sauce
can i tried the kit tire
need help for this since i dont have kit tire and dont want to buy something that dont gonna work
#473
#475
There was a gearing rule before, but now that everyone in my club has a M07, we went to open gear as the track is just right to have a good gear between the highest and medium available, but even my best tuned/hopped up M05 was just a tad under a basic M07 Concept on the timming and scoring. And the M07 has a huge advantage as well over the M05 in my other asphalt club pals. We tried to conpensate the diffirence with open motor, but a 13.5 was burnning up the front tires to pieces on carpet
#476
I am curious on some hop ups If anyone has them, like the Aluminum Steering Arm/Bridge, Are those lighter than the stock parts and What diffirences you've seen
#477
Alloy parts are usually heavier than the stock plastic items.
The alloy steering bridge is listed at 6g the alloy steering arms 10g.
#478
my easy fan mount
a smal spacer and a longer bolt
#480
The bearing like that is normal, but note one bearing is smaller than the other...as in the manual. And as for ride height, 4-5 is okay
