Tamiya M-07 Concept
#31
Originally Posted by KA2AEV
Al you will find a lot more info on the Mini Forum that Tony Gray mentioned previously!
They already have them built on there as well as the guys already discussed the chassis
problem you're about to experience
You mean the Mini Cooper thread, correct?
Yes Sir!!!
#32
Put the diff in last night. Everything worked smooth
I did clean out the bearings from the heavy lube Tamiya uses. Oiled the bearings with bearing oil. Made the drivetrain smooth and freed it up.
Love the simplicity of the drivetrain.. Makes it ultra easy for maintenance
#35
Also the module is also too big: it's the same as the m03... Every new model has to be better than the previous one ...
#36
Still too much tooth contact for my taste. It looks like more contact than my m03 with chamfered gears: tamiya should try to make those gears smaller...
#37
If we look at the gear contact points, we can say that the spur&pinion contact point is good or not much can be done there in reducing the size of the contact point, but the next contact point between the spur and idler gear is much larger and the contact tip of the idler can be reduced to a good size(3mm to 4mm) . In addition, the contact point between the idler and the diff gear is even larger(12+mm) when only about 4mm is needed... My m03 manta ray diff is around the 5-7mm mark which I thought was huge for such low power, but tamiya seems to want to continue down the chunky gears path(maybe for perceived durability) that keeps hurting performance...
I don't even want to mention rotational mass losses, windage losses, noise losses, and gear vibration(wiggle) losses....
#38
Apologies if this has already been answered, but the gears look the same as ab M05? So the gear diffs I have will suit?
It is definitely a more user friendly layout, maintenance should be much easier.
#41
Got mine on the way Friday! So excited....this will be my first mini since the M01
#42
I am awaiting (also my for my M07 co-incidentally) for someone to post the all up grams of the complete car with a stock size battery pack. Probably just the pics but I perceive the M07 as a bit of a lead sled against the shorty M03 ;-)
Thanks and regards
Dave
Thanks and regards
Dave
#45
Mine was 1305gr all stock kit build with a gens ace 7000 battery and a Miata body. Motor was the TCS spec'd Reedy and I use a Hobbywing xr10 Pro Stock Spec esc. Servo was a shorty Savox and receiver is a Sanwa RX-472
