Old 06-22-2017, 08:04 PM   #1
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Default Cleaning silicone grease off?
What do you guys use to clean silicone grease leakage off of diffs?
I tried a few chemicals but it doesn't get it off as easily and still leaves trace amounts.
Dan is offline   Reply With Quote
Old 06-22-2017, 08:24 PM   #2
Trace amounts don't tend to matter.
If you want to get them super clean, degreaser - citrus is fine - in an ultrasonic cleaner works well.
cplus is offline   Reply With Quote
Old 06-22-2017, 09:40 PM   #3
Regional Moderator
disaster999's Avatar
motor spray, or lighter fluid
disaster999 is offline   Reply With Quote
Old 06-22-2017, 10:03 PM   #4
If I want really clean I use simple green with old toothbrush than spray with some brake cleaner and wipe it off the best i can.
GoombaTroopa is offline   Reply With Quote
Old 06-23-2017, 01:57 AM   #5
Dan
Dan's Avatar
Thanks for the tips guys
Old 06-23-2017, 04:29 AM   #6
Which type of material do you want to clean?
Silverprout is offline   Reply With Quote
Old 06-24-2017, 03:03 AM   #7
Brake cleaner does the job. I would suggest to get rid of the leakage first
Macio4ever is offline   Reply With Quote
Old 06-24-2017, 03:29 AM   #8
Racermac73's Avatar
cleaning gum works better than anything and doesnt harm plastic.
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Old 06-24-2017, 03:38 AM   #9
Also, carbon fiber plates don't like solvents at all !
Old 06-24-2017, 04:08 AM   #10
I used to use naptha to clean out my 1/8th scale offroad diffs. I've never had it harm plastics but it is a solvent and never had a reason to use it carbon fiber.
Rebuke is offline   Reply With Quote
Old 06-25-2017, 01:38 AM   #11
Hello,
Here is a chart for those who not only counting on luck
http://www.cue-inc.com/F34B-CHEMICALRESISTANCEGUIDE.pdf
https://www.google.fr/url?sa=t&rct=j...9rLGvwBJkavNdA
PS : I'm not a Russian roulette champion
Old 06-25-2017, 04:19 AM   #12
thanks post
hero9x is offline   Reply With Quote
Old 07-04-2017, 03:26 AM   #13
Skiddins's Avatar
In the USA the brake cleaners I came across seemed to contain nasty ingredients, and using them in anything other than an open air came close to making me feel sick.
If you can get hold of Wurth, it contains Naptha, like lighter fluid, which should be fine for cleaning without effecting the plastics. Just don't let it get on any silicone O-rings etc as they'll swell up.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-05-2017, 01:35 PM   #14
Send a message via ICQ to iliveonnitro Send a message via AIM to iliveonnitro Send a message via Yahoo to iliveonnitro
I would avoid brake cleaner. It can eat away at rubber and some plastics. Far less harsh chemicals that will work just fine. Simple green, WD40, etc. Havent tried it, but a baking soda/water paste might even work.
iliveonnitro is offline   Reply With Quote
Old 07-06-2017, 02:51 AM   #15
Skiddins's Avatar
That's why everyone uses Wurth brake cleaner
Xray X12 2018
Xray X1'16
RCDisco.co.uk
