Like Tree51Likes
Old 07-03-2017, 12:43 PM   #61
Tom1977's Avatar
Originally Posted by syndr0me View Post
Cool looking car. Could be a fun project. Does Tamiya still make their c-hubs from balsa?
No, glass!
But there are ways to cure that.
Tom1977 is offline   Reply With Quote
Old 07-03-2017, 01:15 PM   #62
nubs's Avatar
Originally Posted by Tom1977 View Post
No, glass!
How are you solving it? TA05?
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 07-03-2017, 01:18 PM   #63
Tom1977's Avatar
Ta05 or Exotek. If you like uncommon caster angles like 5 degree, Square from Japan has nice aluminium C-hubs too.
Old 07-03-2017, 04:53 PM   #64
syndr0me's Avatar
Trader Rating: 32 (100%+)
Bummer.
syndr0me is offline   Reply With Quote
Old 07-03-2017, 08:53 PM   #65
Tom1977's Avatar
Bummer.
Take it or leave it. The only other way is not to crash your car. This until Tamiya gives us finally an update of their c-hubs.
OSherman likes this.
Old 07-03-2017, 10:27 PM   #66
OSherman's Avatar
There's a concept
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 07-04-2017, 12:14 AM   #67
kentech's Avatar
・This is an R/C 1/10 scale shaft-driven 4WD chassis assembly kit. Length: 371mm, Width: 185mm, Wheelbase: 258mm.
・The chassis is based around a 2mm thick aluminum lower deck and 6mm thick center stiffener, which give a blend of rigid pitch damping and flexible roll. The number of screws used to attach the stiffener can be changed to alter chassis rigidity.
・The lack of an upper deck lowers the chassis' center of gravity.
・A largely overhauled layout includes updated motor positions and bulkhead design.
・The motor is longitudinally mounted. Users can choose from 3 layouts (front; mid; rear) to adjust performance depending upon conditions and driving style.
・Comes with TRF super short big bore dampers.
・Motor clearance can be adjusted simply from above, for quick in-pit tweaks.
・Steering linkage components are installed directly onto the bulkhead as opposed to being attached to the chassis. This removes any effect upon chassis roll.
・Highly-efficient shaft-driven 4WD is achieved with a front direct coupling and WO universal shafts, plus a rear gear differential unit and aluminum drive shafts.
・Proven TRF418 suspension arms and TRF419 rear uprights are employed.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 07-04-2017, 12:17 AM   #68
Tom1977's Avatar
TBEvo07 (#42315) will offer 3 motor positions - front, mid, rear!
6mm center stiffener is attached with multiple screws which can alter to set up chassis flex.
Steering assembly is completely attached to the front bulkhead.
Seems the kit will be soon released.
https://tamiyablog.com/2017/07/offic...evo-7-chassis/
Old 07-04-2017, 07:36 AM   #69
A very nice update.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is offline   Reply With Quote
Old 07-04-2017, 09:11 AM   #70
Airwave's Avatar
Just LOL
MatsNorway likes this.
Airwave is offline   Reply With Quote
Old 07-04-2017, 09:16 AM   #71
OSherman's Avatar
awesome!!...looking froward to this kit
•KO Propo America
•EXOTEK
Old 07-05-2017, 03:01 AM   #72
Originally Posted by Airwave View Post
Just LOL
What are you lolling at??
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 07-05-2017, 03:33 AM   #73
MGU
MGU's Avatar
Hmm, I always thought the reason you put the motor the way it is with current touring cars (perpendicular?) is to decrease the torque steer on acceleration and breaking. Now I see that the motor here is setup parallel to the shaft... Can someone explain this?
MGU is offline   Reply With Quote
Old 07-05-2017, 03:57 AM   #74
gigaplex's Avatar
Keeps the weight close to the center and increases efficiency as there's less gearboxes. The Evo 6 had it perpendicular but the Exotek Exo 6 conversion was a popular way to get it parallel again. Torque steer essentially doesn't exist with a brushless stock motor where these cars are popular.
gigaplex is online now   Reply With Quote
Old 07-05-2017, 06:00 AM   #75
nubs's Avatar
Torque steer comes from rotating mass. Specifically when you have the drive train all rotating in the same direction. When you have the motor perpendicular, there is one in fact torque steer. However when the motor is fit longitudinal to the drive train, it actually rotates in the opposite direction of the drive train which creates a somewhat equal amount of torque steer in the opposite direction. In other words have the motor longitudinal counters the torque steer.
Tamiya FF04 EVO FOR SALE RC CAR 1/10 FF FWD marshallsbbq R/C Items: For Sale/Trade 8 12-07-2015 07:31 PM
TAMIYA FF04 EVO Chassis Thread RC MARKET Electric On-Road 8 06-02-2015 03:31 AM
Tamiya TB evo 5 D1drifter R/C Items: For Sale/Trade 7 05-19-2012 01:00 PM
Tamiya TB EVO III ecct0611 R/C Items: For Sale/Trade 9 09-14-2009 01:52 PM
