Like Tree2Likes
  • 1 Post By WagwanBumba
  • 1 Post By Airwave
Old 06-12-2017, 11:04 AM   #1
xevias's Avatar
Default Throttle/Brake settings
Do you have your radio trigger settings on 70/30 or 50/50?
Why? What are the pros and cons?
Do you change the setting for different classes (F1, VTA, TC, 1/12th)?
xevias is offline   Reply With Quote
Old 06-12-2017, 12:07 PM   #2
corallyman's Avatar
Trader Rating: 99 (100%+)
It has always been my understanding that if you have a wheel/trigger radio you should be 70/30. If you use a stick radio you would most likely use 50/50. The reason being is that is equal to the physical throw of the radio.
By accident, I once bought a wheel/trigger radio but by default the radio was set 50/50 instead of 70/30. I was supposed to change it but I missed it for several weeks.
The result was very challenging to get the correct feel on low grip asphalt
corallyman is offline   Reply With Quote
Old 06-12-2017, 06:05 PM   #3
For electric,it really makes very little difference. I have tried both. You should calibrate your ESC with the radio's end points and neutral points and it all becomes agnostic to the electronics.
I don't run nitro but I understand it's more applicable for nitro.
Marcos.J likes this.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 06-13-2017, 08:19 AM   #4
Airwave's Avatar
On high level sticks radio, you can fine tune the spring tension, so for me it is better to go for 70/30, as you can have more travel for forward and less for brake...
scirocco14 likes this.
Airwave is offline   Reply With Quote
HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD COBRARACING Radio and Electronics 12050 Today 05:52 AM
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Inferno MP9 thread captain america Nitro Off-Road 20015 05-19-2017 02:14 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
