Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-22-2002, 04:31 PM   #1
Default TB-01 hop ups
what would be some of the best hop-ups to get for this car? i heard of using the tg-10 stearing instead of the stock one. anything else? thanks tamiya 4 life
ROLLINGaFTGT is offline   Reply With Quote
Old 11-22-2002, 05:18 PM   #2
Dan
Dan's Avatar
Trader Rating: 18 (100%+)
Get ball bearings unless you have them already. Then the aluminum motor mount. This lets you use different pinion/spur combos instead of the fixed setup.
Then there are numerous other upgrades depending on your budget. CF chassis, long arm suspension set, etc.
Dan is offline   Reply With Quote
Old 11-23-2002, 01:58 AM   #3
give up on the TB-01, if you want to race spend the same amount of money, and pick up a good used race quality chassis, i have recently run the TCS series and spent a fortune on tamiya hop ups and it is still a piece of shit
Feral Racing Batteries
Windsor Hobby and Racing Centre
unit 21/64 Drummond St
South Windsor
Ph. 02 4577 3166
Besercoe is offline   Reply With Quote
Old 11-25-2002, 12:29 AM   #4
Well, you may buy the optional TB 01 long suspension arm set with the TB evo UJ. It is more stable than using the alum set for tg10. And yes, the TG10 alum steering arm is worth getting. less slop. But it will cost you a fortune to get all this hop up. So I advise you to get the TBEvo3 or any other cars and if you intend to go for serious RC racing provided you have the cash. trust me, it is just now worth the money to mod. I have the mod TB01 and it cost a fortune
RetroTamiya is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
