Like Tree2Likes
Old 05-29-2017, 01:52 PM   #1
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Questions?? Servo Savers
Looking through chassis shots of cars from the Reedy Race I notice a few people still run servo savers. I usually don't as just find them big and bulky and servos now days can take more abuse. Do you run a servo saver and why?
Drift_Buggy is offline   Reply With Quote
Old 05-29-2017, 02:46 PM   #2
kerry's Avatar
$200 dollar servo, and $13 investment to protect it..........kind of like a seatbelt....glad you have one when you need it
kerry is offline   Reply With Quote
Old 05-29-2017, 03:35 PM   #3
I've always used one so I don't really know any better. I don't see a downside in using them.
Atjays is offline   Reply With Quote
Old 05-29-2017, 03:36 PM   #4
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
I run a servo saver (X-ray brand) on most of my cars. Had a few other cars without servo savers too but then a crash broke my $120 servo. Put back on the servo saver.
Dan is offline   Reply With Quote
Old 05-29-2017, 03:40 PM   #5
Trader Rating: 24 (100%+)
I really like the XRAY servo saver, ironically the only time I didn't like it was on my X12 because I was having a hard time getting the bump steer out.
fenton06 is offline   Reply With Quote
Old 05-29-2017, 03:48 PM   #6
Same. Only go with xray
TeamThibault is offline   Reply With Quote
Old 05-29-2017, 04:37 PM   #7
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
it can save you from a DNF
Old 05-29-2017, 05:20 PM   #8
The Xray servo saver is so good - why no one else can make a race worthy saver boggles the mind.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is offline   Reply With Quote
Old 05-29-2017, 07:10 PM   #9
Metalsoft's Avatar
Trader Rating: 69 (100%+)
Kimbrough....Been running one for ages...Just as good at half the cost.
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 05-29-2017, 08:08 PM   #10
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Tamiya makes a pretty good servo saver as well. ill typically run one indoors with clicktrack and run an arm outdoors.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 06-04-2017, 05:13 PM   #11
Send a message via AIM to GuyIsDamGood
My brother-in-law(my wife's brother) doesn't run with a servo-saver. He says it adds unnecessary weight to the chassis.
I always run with a Servo-Saver installed on the chassis.
GuyIsDamGood is offline   Reply With Quote
Old 06-05-2017, 06:47 AM   #12
LJH
What are we talking, 8-10 grams? I think as long as the SS is accurate there is not much of any downside to running a saver. I run the medium Kimbrough's for years and have never had an issue with them.
Cheers,
Jim
Metalsoft likes this.
LJH is offline   Reply With Quote
Old 06-05-2017, 07:54 AM   #13
Skiddins's Avatar
I run a saver, particularly indoors.
Running without always ends one of two ways (eventually);
1) Broken gearset
2) Slop in the front bearing etc, where the extra load in impacts starts to cause issues with the casing.
Both will prove more expensive/inconvenient than a server saver.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-05-2017, 07:58 AM   #14
I have not used the x-ray saver, but ever other one I used made the car wonder a bit more than I liked. I had one from MST that seemed alright but the plastic bit that the spring pushed against broke after only a dozen races. Since I have switched to no servo saver I have only had two incidents that required a replacement set of servo gears in the last 9 months. One was expected as I blew a corner and caught the right front wheel on a 90 corner in a high speed section (No one liked the track layout that night). The other was less violent but similar where one of the steer wheels caught a rail with no other parts of the car to absorb the impact. The servos in question are rated at 100 oz-in @ 6V. In both cases a simple replacement of the damaged gears and the servos are back in use.
jkaetz is offline   Reply With Quote
Old 06-06-2017, 01:33 AM   #15
Thanks for all the replies.
In regards to the Kimbrough Servo Savers, does any know if there is a place to see the specs on the hole to hole distance with the small / medium / large servo savers?
8ight-T 3.0 Servo Saver jedi.mind.trick Nitro Off-Road 7 03-24-2015 05:34 AM
Mini 8ight Servo\Servo Saver Issues Airious Micro and Mini Scales 23 02-09-2013 04:26 PM
servo saver question dreaux Nitro Off-Road 30 05-30-2010 07:02 PM
