Old 05-16-2017, 01:21 AM   #1
niznai's Avatar
Default Belt source
Hi guys, need a belt for a project, I am looking at about 230 teeth, so about 690mm long. 3mm wide.
Anyone know of a source?
Databases on the interwebs don't go that high.
Kawada single belt cars belts are longer by about 30 teeth. Not sure about the Tamiya TA07 belts, if anyone knows the tooth count on that, please let us know. My guess is it's not going to be far enough from the Kawada.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-16-2017, 02:05 AM   #2
Probably a bit dated:
https://driftmission.com/guides/belts-guide/
But you'll be looking for 30-S3M-690
You can fairly easily find 150 (15mm) as they're timing belt width.
High Torque Timing Belts - S2M, S3M, S5M, S8M, S14M?MISUMI?MISUMI
These guys have got 6mm.
I'm assumming you're still looking for the 3mm teeth pitch that are used on RC cars.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 05-16-2017, 02:07 AM   #3
Actually these guys say any custom width available:
TIMING BELTS > STPD/STS SYNCHRONOUS BELTS > STPD/STS 3M Pitch Synchronous BeltsD&D Power Transmission Products
ST - Losi 22T 2.0
Old 05-16-2017, 04:08 AM   #4
niznai's Avatar
Hi guys, thanks, yes, I've checked Driftmission, the last belt on the page looks promising, it seems to me it's about 222 teeth (if the length is indeed 666mm; the site says it has 215 teeth, which I think it's wrong because 666:3=222), which would be close and most likely good.
I have also discovered the Kyosho Optima belt is 220 teeth, so close enough.
The TA07 belt is 250 teeth, not so sure.
I've ordered the Optima and MST belts from Rcmart, we'll see what happens and take it from there.
I have visited the Misumi page as well, but I can't use 6mm wide belts, and they don't have them any thinner.
The custom made belt sounds like what I need, but at least if none of these two belts I ordered work, I will be in a better position to order something custom. I mean I don't want to order something that will most likely be quite expensive by taking a guess and then discover it doesn't fit.
We'll see.
Team Greasy Weasel
Old 05-16-2017, 05:19 AM   #5
Tom1977's Avatar
Default Tetsujin
RC belts:
http://http://shop.tetsujin.biz/index.php?main_page=index&cPath=16&sort=20a&page=1
Tom1977 is offline   Reply With Quote
Old 05-16-2017, 10:34 AM   #6
niznai's Avatar
Great stuff, thank you. Looks like they have one belt in 699mm (233 teeth). Seems spot on, but for now, I will wait. Thank you again, excellent source.
Team Greasy Weasel
TLR 22-4 THREAD 1badgoat Electric Off-Road 8846 08-15-2017 05:11 PM
New TC4 Belt underway? imr Electric On-Road 15 05-26-2005 03:11 PM
