Old 04-23-2017, 11:41 AM   #1
Default Team Associated TC7 Torque Steer????
Hello,
Having a bit of trouble with my TC&, its driving me nuts and I can't work it out!
While racing this weekend, when on full power the car had the tendency to pull left, quiet a lot!
If adjusted the roll bar, shocks, aligned the toe front and rear, everything is nice and tight with thread lock.
If the power goes on gently its not as bad but still pulls.
Any thoughts or experience with this?
Cheers.
Hoops369 is offline   Reply With Quote
Old 04-23-2017, 12:08 PM   #2
ThePanda's Avatar
Trader Rating: 64 (100%+)
Is the chassis tweaked or is there more friction on one side than the other?
ThePanda is offline   Reply With Quote
Old 04-23-2017, 12:24 PM   #3
Broadwater's Avatar
Could also have a bad bearing on one side of the car.
Darren B.
Broadwater is online now   Reply With Quote
Old 04-23-2017, 02:21 PM   #4
Chassis is ok, but haven't checked the friction.
Bearings seem ok but worth checking out.
Thanks guys, think I'm going to have to do a full strip down and rebuild the front end.
Old 04-23-2017, 03:11 PM   #5
gigaplex's Avatar
Also check weight distribution and spring preload. You want it to be even left to right. The sway bars can also tweak the suspension if not adjusted correctly.
gigaplex is offline   Reply With Quote
Old 04-24-2017, 05:35 AM   #6
Wheel bearing shimming or overtightening of the wheel nuts: you might need to shave the back of your wheel hexes... It happens alot to the AE cars....
bertrandsv87 is offline   Reply With Quote
Old 04-24-2017, 07:16 AM   #7
AMZ
AMZ's Avatar
--I had a receiver do that to a servo on a a TC last month. On the bench , a quick blip to full throttle made the steering servo go left for a split second.
I replaced the receiver , but rerouting the antenna wire would probably have fixed it.
--Sounds more like a bad bearing in a hub , it can't take but so much pressure , then it locks up,or drags.
AMZ is offline   Reply With Quote
Old 04-24-2017, 10:12 AM   #8
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
I would check your droop settings make sure they are equal on both sides (left and right)in the rear and front arms.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
