Like Tree13Likes
Old 04-19-2017, 05:28 PM   #16
Wow, that is a big difference... Lcg only for mod racing then....
bertrandsv87 is offline   Reply With Quote
Old 04-19-2017, 05:52 PM   #17
gigaplex's Avatar
Originally Posted by robk View Post
Just threw the lcg pack on the turbo, note these numbers are the second cycle today:
8.0v - 2sec
7.9v - 3 s
7.8v - 5 s
7.7v - 8 s
7.6v - 12 s
7.5v - 30 s
7.4v - 69 s
SEC 340
IR 11.8
MAHr 2833
Ave. V 7.18
Compare to an old HobbyKing Nano 4600 standard shorty on the first cycle today (cold):
8.0v - 7sec
7.9v - 17 s
7.8v - 44s
7.7v - 78 s
7.6v - 109 s
7.5v - 149 s
7.4v - 200 s
SEC 510
IR 7.9
MAHr 4250
Ave. V 7.34
This is a junky practice pack. The lcg has maybe 5 cycles on it since it has only seen the turbo for testing. Charge at 10A, discharge at 30A
Is that representative of LCG as a whole, or is that a specific LCG pack?
gigaplex is offline   Reply With Quote
Old 04-19-2017, 06:13 PM   #18
robk's Avatar
Trader Rating: 22 (100%+)
That is one pack, but I have another pack from a different brand that wasn't much different/better. And they are shorties, which might be part of the problem.
Old 04-20-2017, 06:53 AM   #19
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by dawgmeat View Post
If you buy these new 2017 LCG/HV/SVH packs don't expect them to reached they're Mah capacity at 4.20/8.40 volts, example I have the Reedy 3.8 Zapper 1s lipo that charge up 7100ish in Mah capacity at 4.20 volts. When charged to 4.35 it barely made over 8000mah. LCG is nothing more than lowered case with the same chemistry
That's only if you buy the HV version of them. Any Non HV pack should reach its capacity or writhin a few percent of it at 4.20 per cell.
The HV packs capacity is rated at 4.35v per cell and why you never get that capacity at 4.20v.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 04-20-2017, 06:58 AM   #20
Team EAM
Originally Posted by JayL View Post
Totally agree Mr. King
Nice to see actual data!
More Mah= more volt over the run
Can't wait to see you in F1 at CTS this weekend
It's not always true. I was a firm believer in the 8200 pack I was selling for a long time and also the IP packs like a lot run that are 7600+. Until my factory sent me a newer style 6000 pack to test. The discharge curve at 40 amps is just as good if not better than the IP packs and my 8200 pack. Plus the IR was lower. It all depends on the chemistry of the pack itself.
One thing I also found when testing HV packs were they were good the first 15-20 cycles and then they went to crap and swelled worse than any other packs Ive tested. It's been about 6 months since I tested any so perhaps they have refined them a little better but I always thought the HV was just a gimmick to be honest.
EA
ASM, RBLove and jlfx car audio like this.
Contact Us
Old 04-20-2017, 07:55 AM   #21
Bar
The latest Nosram/LRP 6400 HV/LCG Graphene seem to be one of the best batteries around at the moment guys using them in blinky boosted and mod, voltage holds up really well and gives lots of punch for blinky racing as well. Probably why there is no stock here in the UK at present at suppliers
Serpentor likes this.
Luke Burr
Bar is offline   Reply With Quote
Old 04-20-2017, 08:13 AM   #22
dawgmeat's Avatar
EA
The down side of 8000mah lipo and above is that they weigh a ton and if you have a A800 like myself which is naturally a light car good luck with that L/R balance
dawgmeat is offline   Reply With Quote
Old 04-20-2017, 09:02 AM   #23
EA
Well I guess testing every pack over time is the only way to go. I just hope more racers would post more videos of their tests.... So far , the turnigy cells seem to be still good for the price, but I seriously question the crazy charging practices I've seen in the pits, with not much more performance gains to just charging at 12A , with no discharge..... Maybe the new cells don't like these practices, and should be charged normally...I remember pulling a few of these racers down the straight with my normally charged fantom 5000 mah(12A) in an overweight tc4 with too much toe (f/r)...Yes they got me in the corners, but they had newer motors/batteries/chassis, and weighing exactly 1350g....There might be a mystery to finding speed, but I will pass on torturing my packs for that last 0.1 second per lap....I might get further trying something else...
Old 04-20-2017, 10:08 AM   #24
Bert, I hate to do this to you but...
The industry standard for charging is 1C, so a normal charge on a 5AH battery is 5 amps. So a 12a charge is pushing the batteries, just not as much as everyone else.
You don't have to go to the mat to get a little more out of the batteries. Discharging then charging does seem to work, but you don't have to do it at near nuclear rates.
jiml is offline   Reply With Quote
Old 04-20-2017, 01:12 PM   #25
I did not push the batteries enough at 12A according to the guys in the pits who charge/discharge at 40A... I know 1C is the standard, but that is more geared towards avoiding lawsuits more than anything else....
Old 04-20-2017, 04:55 PM   #26
gigaplex's Avatar
Simply being a shorty will do that. We need to compare LCGs to their equivalent length packs to get a fair picture.
Old 04-20-2017, 05:47 PM   #27
robk's Avatar
That is what I did. I was pointing out that those who got good results with full length LCG packs may have done so because they were full length. The short LCG packs I have are not that good compared to standard short packs.
Old 04-20-2017, 05:54 PM   #28
gigaplex's Avatar
My bad, I didn't notice that the "standard" pack you compared to was also a shorty.
Old 04-25-2017, 02:28 AM   #29
https://www.youtube.com/watch?v=yLdGhzg_wEE&t=881s
B.S. is offline   Reply With Quote
Old 04-25-2017, 04:48 PM   #30
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I tested all my batteries last night on my turbo GFX and the LCG 5000mah Fantom held the voltage over a 6 minute 20 amp discharge as well as my SMC 6000 mah 2s full size packs. They were also .10 of volt higher on the start of discharge to the end of discharge over my GensAce batteries. That was 3 Fantom LCG 5000 2 SMC 6000, 2 GensAce 6000mah, 1 GensAce 6500, GensAce 5000 mah, and a GensAce​ 5800 mah.
The SMC had the lowest IR 1.6 average per cell, LCG 1.8 and the GensAce were all mid 2s IR. In 6 minute's the packs all of them had a 1680 range of mah drawn out.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Official Team Associated RC10 B5m Mid-Motor Thread RCBuddha Electric Off-Road 21060 06-22-2017 09:35 PM
Kyosho Ultima RB6 & RB6.6 Car Thread Cpt.America Electric Off-Road 14290 06-18-2017 09:02 AM
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
New batteries for stock racing Zhangesh Electric On-Road 7 08-14-2016 11:43 AM
Serpent 720 rcrossco_1 Nitro On-Road 5073 04-16-2012 08:42 PM
