Like Tree58Likes
Old 05-20-2017, 07:26 PM   #46
Considering I work in the racing industry and on 1:1 prototypes and open wheel cars, this intrigues me greatly.
British Menace, texastc and G-rem like this.
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 05-21-2017, 11:41 AM   #47
It looks awesome. This is how F1s should look like, not ancient chassis with low power motor
Originally Posted by G-rem View Post
I like what you are describing for your design, it would be a big step further in the "scaleness" game, as real F1 have a motor implementation like this! But finding helical "pinion gear" will be hard I think As spur/gear diff, you should use Awesomatix A700 gear diff (#GD2), they are the best on the market!
Regards,
G-rem
Dou you mean direct drive via bevel gears? This will be problem, as angle of bevel gears changes with gear ratio. So either you need to change whole set or add some standart gears (even with close to 1:1 ratio), so you can change gear ratio with pinion only.
If you want first variant, you can look for some CS sets for shaft driven 4wds, there were whole sets available for fine tuning of rear overdrive.
Second variant wont be as efficient, but still more eficient than belt drive or FGX setup and you could gain some additional space for electronics thanks to of-centre motor
Papi is offline   Reply With Quote
Old 05-31-2017, 05:35 AM   #48
This is very impressive. If you want to increase the scale realism. Look at going to 380 size motor. Then you can push servo back and add more realism in the front. Raised nose etc. on 3 cell you get 200W+ from the Novak ones. Should be plenty to go fast.
MatsNorway is offline   Reply With Quote
Old 05-31-2017, 02:52 PM   #49
aracefan's Avatar
Trader Rating: 38 (100%+)
So much awesome in this thread G-rem. Sub'd.
G-rem likes this.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 05-31-2017, 03:03 PM   #50
I'd like to see your option for the double front shocks with rocker arms. The monoshock looks like it will have very high rising rate, which concerns me.
G-rem likes this.
glennhl is offline   Reply With Quote
Old 05-31-2017, 10:25 PM   #51
G-rem's Avatar
I'll post picture of that configuration soon!
What I can say it is the fact that front suspension has very little range of movement, about max 5mm, so the rising rate does not really matter.
Regards,
G-rem
G-rem is offline   Reply With Quote
Old 06-01-2017, 07:24 AM   #52
Regards,
G-rem
If it only moves 5mm, then you will probably need to lengthen the push rods to have the rocker higher up into the middle of it's travel. When it first moves off the position it's in now, the shock hardly compresses at all.
By the way, I just don't understand why something like this hasn't been done. The 1/12 scale suspension that they use now just doesn't hack it for me. If I bought a F1 car, I'd definitely buy the one you are developing. Outstanding work!
G-rem likes this.
Old 06-20-2017, 07:49 PM   #53
Update photos? Awesome work so far, keep it going!
Shaun Barron.
Big and Important Titles
2 lines of sponsors!
Cuz Big and Important Titles and 2 lines of sponsors are way cool
Shaun B22 is offline   Reply With Quote
Old 06-20-2017, 08:38 PM   #54
G-rem's Avatar
Final exam @ school today, I'll be able to go back to the design very soon
texastc, Antimullet and Mr Brooksy like this.
Old 06-21-2017, 03:52 AM   #55
Mr Brooksy's Avatar
Apart from the obviously well thought out and outstanding design that's gone into this car, its the little things that I'm loving.
1) you have thought about a flat floor like a real F1 car. Like seriously the big companies at best have a splade out lower deck. Your design can actually have real working efficiency and even measurable downforce with a good diffuser.
2) the lack of wide pan style rear end is awesome. You can actually make the F1 car look "like" an F1 car instead of those flaming awful looking slab sided monstrosities that are popular to fit over the jungle gyms at the rear of current popular F1 chassis!
Just to name a few.
G-rem and Antimullet like this.
- Tamiya FF01 Nissan Primers - 2008 Focus RS shell.
- Tamiya F104 Ferrari 2012. Painted in 2012 Williams Renault livery.
- Serpent F110 SF2 wide edition with 1999 Damon Hill Jordan Mugen Honda; 1996 Damon Hill Williams Renault
- TT02 Ferrari
Mr Brooksy is offline   Reply With Quote
Old 06-21-2017, 06:03 AM   #56
British Menace's Avatar
Default Been a while........
G-rem....
How are you man?
Amazing what you can do when you get board waiting on the big companies to make the car you really want to own isn't it?
You have done an incredible job here G-rem! It's looking very good.
I remember your work on your other F1 chassis and this has your "stamp" all over it.
Good luck with your prototype and testing. I look forward in hearing how it goes mate.
Regards
BM
G-rem likes this.
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 06-21-2017, 01:07 PM   #57
G-rem's Avatar
Thank you very much guys! I really appreciate the interest you all show up in my project, which make me happy to see I am not the only one to desperately wait for some manufacturer to think, design, built a real 1/10 F1 like some are able to do so at 1/5 scale!
I have to say the current period is very suitable for that kind of iteration, I'd never tought some years ago to design my own car, based on what I really think it's essential for me, and print it in 3D to make a actual prototype.
Btw, I think I am entering the final stage of prototyping; I still need to make some minor adjustments accordingly to the conclusions based on the latest printed parts, and also design new ideas that came up during my "resting" period when I had exams at university^^ Now I'm done with that, I will be able to focus entirely on my car so stay tuned!
Regards,
G-rem
texastc and DavidNERODease like this.
Old 06-21-2017, 03:08 PM   #58
texastc's Avatar
my mind is still blown. My late 1980s education does not grasp the mystical things you are doing.
G-rem and aracefan like this.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 06-22-2017, 08:13 AM   #59
G-rem's Avatar
Some improvement of the front monoshock system:
I added 2 small PN mini-z front springs in order to have some influence on lateral moves when cornering, so that under-load side can move up sligthly (around 3mm travel) while the other side can move down.
It also act as a sway bar, and I can fine-tune the effect by switching to other rate springs.
G-rem
texastc likes this.
Old 06-22-2017, 08:32 AM   #60
A great car !!!
enginesjohn is offline   Reply With Quote
Official Xray XB2 2WD Buggy Thread BentKa Electric Off-Road 5003 Today 09:34 AM
Pro 10: 235mm Le Mans Prototype Pan Car Discussion liljohn1064 Electric On-Road 4332 Today 08:15 AM
Hot Bodies D815 Tessmann Worlds Edition My ST-RR EVO Nitro Off-Road 2823 06-08-2017 04:24 PM
ARC R11 2017 1AGOFST Electric On-Road 25 01-11-2017 05:39 PM
New 1/8 Buggy Design/Prototype xemanuelli Nitro Off-Road 214 11-10-2016 07:04 AM
