Like Tree2Likes
  • 2 Post By anthonyscardina
Old 04-10-2017, 09:31 PM   #1
Default Shock air removal tool. Do you really need 1?
As the title says. If I just let the shocks sit and move a few times would that be good enough?
TeamThibault is offline   Reply With Quote
Old 04-10-2017, 09:38 PM   #2
of course you don't need it, but I've heard it really speeds up the process.
Scott Smither and JoshuaRC10 like this.
anthonyscardina is offline   Reply With Quote
Old 04-10-2017, 10:09 PM   #3
b20btec's Avatar
If you value your time like I do it's a easy decision.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 04-10-2017, 10:13 PM   #4
I seen a video of guys dropping thier sauced 1/12 foams in one. I want one just to try that.
RCJer is offline   Reply With Quote
Old 04-11-2017, 01:32 PM   #5
It is a nice to have tool, but by no means essential. It will definitely speed up shocks building, but if you let them sit for 15-20 minutes, you will essentially get the same result.
rhodopsine is offline   Reply With Quote
Old 04-12-2017, 11:50 AM   #6
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
I had one and I only used it when I was on a time crunch , so no you don't need it
Old 04-12-2017, 01:30 PM   #7
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
I only use mine to hold the shock while I do other things. If I buy a new kit I have to build, sometimes I build the shocks first and let them sit in the stand while I build the kit.
Drift_Buggy is offline   Reply With Quote
Old 04-12-2017, 02:17 PM   #8
dan_vector's Avatar
Trader Rating: 25 (100%+)
Not essential but yeah you need one! I've found even if you leave a shock sit for 24 hours and then put it in a shock pump even more air comes out! For Trackside oil/piston changes the pump is extremely handy. Shocks I've built using the pump feel better than shocks not built using one.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 04-12-2017, 03:05 PM   #9
Shock oil consists of 20% air molecules so you can pump for a long time and if you ever do get rid of all the air your shock wont be able to compress any more.
Good info here;
https://www.youtube.com/watch?v=LwAV...=youtu.be&hd=1
https://www.youtube.com/watch?v=556m...ature=youtu.be
Rodney Racer is offline   Reply With Quote
Old 04-13-2017, 02:19 AM   #10
Lonestar's Avatar
Initially I thought you knew what you were talking about...
... then I changed my mind
I'm sorry to be so derogatory, but c'mon, this is the post of the year for me!
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 04-13-2017, 03:39 AM   #11
Geberit's Avatar
The bubbles don't come from oil it self! When you pump too hard the air gets sucked from the bottom of the shock where the O-ring sits.
Geberit is offline   Reply With Quote
Old 04-13-2017, 06:52 AM   #12
Not quite... the tool creates a vacuum in the whole chamber, not just at the top of the shock. When you create too much vacuum, the bubbles you see are actually the oil itself boiling (the boiling point is around 92 Celsius at normal pressure). You don't need to remove all the air, just a partial vacuum to speed up getting the air out of the shocks.
Martin Paradis
Old 04-13-2017, 07:27 AM   #13
Danny-b23's Avatar
Good info here;
No need to be so aggressive.
He's actually somewhat correct. Gas solubility in liquids is a phenomenon that allows air (or other gases) to be dissolved completely within a liquid. In this case the solvent is the silicone oil and the solute is air.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 04-13-2017, 07:42 AM   #14
He's actually somewhat correct. Gas solubility in liquids is a phenomena that allows air (or other gases) to be dissolved completely within a liquid. In this case the solvent is the silicone oil and the solute is air.
True, but in this case, the solubility of air in PDMS (Polydimethyl siloxane, what Silicon oil is made of) is marginal at best and can be ignored as far as effect goes for our purpose. This is what makes it such a good shock fluid, it is actually quite inert and will keep its properties for a long time.
Martin Paradis
Old 04-13-2017, 09:21 AM   #15
Danny-b23's Avatar
Martin Paradis
Right, no where near 20%.
Danny Buck
General offroad setup Lots of great info! slim jim Electric Off-Road 20 07-04-2017 10:26 AM
Tools! eR1c Electric On-Road 98 11-12-2016 05:36 AM
