Capricorn Touring Car Ride Height Help
Been away from touring cars for a few years and come back to buy a used Capricorn TE04 MDM and for the life of me I can’t adjust the ride height lol.
adjusting the shocks preload doesn’t do anything, I don’t think shims are the answer. The only way to get any adjustment is the grub to adjust the droop, but then have no suspension travel.
Capricorn are one of the top chassis manufacturers, I know there’s a way to adjust it out of the box without having to buy these height adjuster sets for the shocks :/ Capricorn website
any help? And I’ve tried this with shocks, bars and everything at the correct length by the manual
The threaded collar on the shocks are your ride height adjustment. The collars you linked to are body height adjusters and they go on the body mount posts only.
Some suggestions -
Back off the droop screws so they don't touch the chassis when checking ride height.
You need some weight on the chassis - battery, motor, servo, etc.
You don't say if you need to go up or down, but the shock collars are really low, they look like they should be screwed up closer to the top of the shocks. It is possible the springs are too short - later touring cars use shorter shocks and springs.
Hope that helps
Some suggestions -
Hope that helps
Some suggestions -
Hope that helps
Some suggestions -
Hope that helps
As others have said, back the droop screws off (use the values in the setup sheet in the manual). Screw the spring collars almost all the way to the top of the shocks. Install the electrics and a battery. Now check the ride height, keeping in mind the car is designed for rubber tyres, which are about 63mm diameter. If your foam tyres are bigger than that, it will impact your ride height.
Regardless of tire size, the ride height should at least change, even if it does not get where you want it to be. If it doesn't even change at all, it's probably not tire size but something else wrong.
Shock total length might be too small. Hopefully the piston is not stuck inside too. Unscrew the bottom eyelet a bit to see if the rideheight goes up. It will allow the spring to lengthen a bit and raise the car from the ground: your springs should spin by hand easily when the tires are off the ground. If not, the shock total length is too small....
Manual calls for 12.5mm rod gap between shock body and ballcup. Encountered similar with the Sakura 20M when manual states to leave an extra 1mm. Overlooked that and couldn’t get my ride height higher than 5.2mm.
Guys, again, the OP didn't complain that he just couldn't get ride height to the value he wanted, he claimed that he cannot make it to change at all. He also said in his fist post that he checked and all lengths were according to manual.
ry_100 do the shock pistons/rods actually move into the shock bodies when you push on the car? When you press on the car by hand, can you get it to bottom out (or close to)? Or does it stay up where it is all the time?
Take the springs off ..... whats it do?
She should drop to the table surface.
What ride height are you at now? What are you trying to achieve?
What spring rates are you using? If its an older foam car or has foam era springs then they are totally too stiff.
