Old 03-23-2017, 02:08 PM   #1
SteveM's Avatar
Trader Rating: 134 (100%+)
Default Brushless Motor Build Question
I recently picked up a used 17.5 motor that runs, but when I look closely I can see the stator moving for/aft in the can when I give and let off power. Are the stators normally glued to the outer cans or are they a snug press fit? I don't think a stator should be moving, but thought I'd ask.
SteveM is offline   Reply With Quote
Old 03-23-2017, 02:17 PM   #2
Ominex's Avatar
As far as I know the stator should definitely not be moving. I've seen both press fit and glue sometimes both. It may work but I would imagine the the motor would heat up. It also probably won't run at its full potential especially if it's sensored. As far as fixing it? Maybe some glue or see what's loose/not right that's letting it move.
I could also be wrong and it works just fine for forever.
Ominex is offline   Reply With Quote
Old 03-24-2017, 05:24 AM   #3
SteveM's Avatar
I took the stator out of the can and used a few dabs of glue on the case and slid the stator back in. Hopefully this secures it enough. Thanks.
Old 03-24-2017, 06:11 AM   #4
bdmpastx's Avatar
That's the new adjustable timing motor. Lol built in reverse turbo.
bdmpastx is offline   Reply With Quote
Old 03-24-2017, 06:36 AM   #5
SteveM's Avatar
Must be a new feature.....LOL
Old 03-24-2017, 09:39 AM   #6
Skiddins's Avatar
Might want to use heatsink compound instead of glue.
The stators are usually, 'interference fit', so if tyou need to fill any gaps the compound will be better, otherwise it won't transfer heat out through the can as well.
When you check the temp after a run, measure the outside of the can as well as the inside through a vent hole.
I usually get 5-7degC difference (hotter on the inside)
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-24-2017, 09:51 AM   #7
SteveM's Avatar
Thanks, I used the thinnest amount possible and only in a few spots just to keep things from moving. I'll be sure to check temps, but in a 12th scale in blinky on 1S things don't heat up much.
Old 03-24-2017, 11:11 AM   #8
Ominex's Avatar
No problem! Good luck!
Hotbodies Ve8 Thread joelwhite Electric Off-Road 13618 04-02-2017 06:46 PM
Traxxas backslash build questions Akrider174 Electric Off-Road 11 03-28-2016 04:39 PM
For Sale: Tekin Pro4 4pole 4600 KV Brushless Motor w/sensor wire Justin Bolin R/C Items: For Sale/Trade 7 11-30-2013 04:23 PM
Trinity Epic D3 - Revtech 21.5 Brushless Motor - USGT JFuel11 R/C Items: For Sale/Trade 10 11-18-2013 10:26 AM
Speed Passion 1/8 scale brushless Applesauce Electric Off-Road 1000 02-28-2013 08:09 AM
