3 Racing Heatsink/Fan
I just picked one of these up but they do not come with any install instructions. I searched the site but did not find any info. Is anyone using this that can provide some insight?
Thanks. |
clamp it on motor :weird:
Thanks. |
if its got a fan you need to solder the fan wires in, i soldered mine direct to the wires cummin off the cells into the speed controller so its always on when the batts are pluged in
just plug and go. |
2 Attachment(s)
no i had to solder mine to the battery wire
i suggest you dont use the fan. unless you want a fried ESC/servo and receiver. look at the wire on the fan side, they are exposed and so close to shorting with and slight movement of the wire :weird:
ive been racing that for ages it might not be as tidy as it should be but thats cause im in the process off a strip down hence the fact most of the car is appart i just chucked it on to show you that i had to solder it onto the wires thats all. also where are they exposed?
look where the wires connect to the centre of the FAN ;) |
1 Attachment(s)
I found the original cooling fan on the 3Racing heatsink a bit too small and it cannot rotate if when I use motor with strong magnetic. I changed it to a bigger 5v fan and connect to my receiver. I need to change the way the fan mount tho - to avoid the wires touching the ground. Basically, the new fan can blow more air into the comm area rather than just the motor can. It helps when I run 23T stock motor (super hot after 8-9 mins of run time).
So this fan pretty much is no good? i was thinking aboiut buying it...
I don't know about this fan but I love my coolcanfan! :nod:
1 Attachment(s)
I`d have to agree the 3Racing fan isn`t the strongest but for US$5 what do you expect.
I`ve mounted the fan so it blows into the comm, rather than onto the can. Cheers |
