Like Tree2Likes
Old 03-09-2017, 12:18 PM   #16
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Turn the timing down to 44*, Gear to 4.0, take the temp after 2 minutes. If under 120, add 2 teeth. Keep adding more and more pinion until the motor comes off @ 140 after 2 minutes and then back down a tooth. Take a full run and check for fade and high temps. Don't trust the current method, that one comes up once in a while but is not a test of the true load on the motor. All that does is generate unnecessary heat. Once you find a speed you like, then play with the timing up and down 4*. You will eventually find the sweet spot.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 03-09-2017, 12:18 PM   #17
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I put my fantom 25.5 on my gforce motor analyser it was on 50` exactly 47•/50/52 ` it pulled 4.6 amps. I think I'm going to gear it 3.4
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 03-09-2017, 12:23 PM   #18
DARKSIDE's Avatar
6 amps for 25.5 is too high....shoot for 3 amps....or around 47 deg timing
liljohn1064 and massenb203 like this.
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 03-09-2017, 12:37 PM   #19
ASM
ASM's Avatar
Instead of 4.448, I would think you'd be looking somewhere around 3.8 or so. How much your set-up is binding up on the black carpet there factors in as well.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 03-09-2017, 11:54 PM   #20
djlove85's Avatar
thinks guys. i'll give a try to see if i'm fast. but this is what the use at 386 in daytona, now i have my fantom @ 3.9 amp and timing @ 45". i can't test it yet i go to the once a month i stay in miami
djlove85 is offline   Reply With Quote
vector fade / fading dots? mourinho Painting, Designs, Graphics and Photography 7 08-21-2013 04:57 AM
Reedy 767 brushes---> fade? Qwiglee Electric On-Road 18 08-31-2004 11:16 PM
