Help wandering steering belt car. >
Like Tree4Likes
Old 03-06-2017, 03:56 PM
Default Help wandering steering belt car.
Have a TRF 419 belt car, and it wants to wander under power and off power, kinda like a torque steer, have rebuilt all shocks, checked everything for binding, replaced the servo and horn, reset ride height, set shock shaft travel equal, tried different receiver, checked all screws.
Slashripper is offline
Old 03-06-2017, 03:58 PM
Suspended
Trader Rating: 76 (100%+)
Check the bearings. Had one starting to seize on me one time that exhibited the same behavior
Govert likes this.
Metalsoft is offline
Old 03-06-2017, 04:13 PM
Bearing shimming differences, and maybe an overtightened wheel nut...
bertrandsv87 is offline
Old 03-06-2017, 06:29 PM
I rebuilt all the bearings, and properly torqued the wheel nuts, everything is free and true.
Old 03-06-2017, 06:53 PM
I guess you have a tweak issue then or left/right weight balance issue if the car comes off good on a hudy setup station...
Old 03-06-2017, 07:10 PM
Sounds like you have a twisted chassis.
Lonestar likes this.
mooby64 is offline
Old 03-06-2017, 08:05 PM
tbrymer's Avatar
With all the different types of plastics for cars, you might want to make sure the plastic compounds for all your a-arms are the same. Not familiar with the 419, so this might not be the issue.
tbrymer is offline
Old 03-06-2017, 08:11 PM
No I don't have a set up board, bought it used, had two other used chassis with it, maybe the guy was a big crasher, and tweaked them all, that could be why he was selling it so cheap.
Old 03-06-2017, 08:25 PM
Johnny Wishbone's Avatar
What surface are you testing the car on? Rug,carpet, polished floor?
Johnny Wishbone is offline
Old 03-06-2017, 08:27 PM
gigaplex's Avatar
You might need to tear it down and check for bent bulkheads, hinge pins etc if that's the case.
gigaplex is offline
Old 03-06-2017, 08:49 PM
Asphalt in front of house.
Old 03-06-2017, 08:52 PM
I already rebuilt 90 % of the car, haven't seen anything to the naked eye that's obvious to me.
Old 03-06-2017, 08:54 PM
wheel-spin, your problem is lack of grip
nitrodude is offline
He gave me 2 other chassis, maybe I should try one of them, what do I look for on a bare chassis just to lay perfectly flat on a glass table?
Old 03-06-2017, 09:13 PM
No the cars steering wanders on and off power in different directions, all my other cars work fine in the same conditions, yeah I thought it might have been the crown in the middle of the street too.
