Anyone ever use JB weld to repair pulled screw ears in CF?
Basically the part I broke (2 actually) won't be around for a few weeks and nobody stocks it. There is about 1mm of material around the screw hold of the counter sunk holes so there isn't a ton of material around it so they pull out on occasion. I have used JB weld for other applications in the past and it does the business I've made a bit of a mold, sanded/cleaned the surfaces, applied a coat, sanded it back and put another coat on. I'm using JB quick which I rarely use but it's all I have currently and it seems a tad soft after sanding back the first coat. Not instilling much confidence but I've applied my second coat and I'll let it cure for a few days to hope it hardens more. It's said to cure in 4 minutes but I'm sure that's not a full cure so I'm hoping after a day or so it'll be a bit harder. Fortunately the pull through was just the size of the ID of the screw so there was a bit of a ridge so filling the hole as well and redrilling will give me a bit more surface to bite to.
Anyone ever done this with any level of success?
I've done a bit of carbon fiber work with laminating epoxy and JB Weld, and both need some heat to complete the cure. It will help the cure if you can heat it up to 80F or so for a couple of hours. I have used a cardboard both with a 60W light bulb as a hot box, but electric blankets work or even putting the parts into a car parked in the sun for awhile.
Hard to say how your repair will hold up but I'd say your chances are good, JB Weld is pretty tuff.
Most laminating epoxy resins can be cured at room temperature, but will be even stronger with a "post - cure" at elevated temperatures.
I wasn't aware third party companies did this type of thing? If so I wonder if they had a waterjet and could cut one out of alum. for me. I'd love the cad drawing for this to just do it myself. I started to create a cad drawing for this just haven't finished it.
Dave
Dave
Thanks guys, i've contacted Cristian. I had asked on my local forum and didn't even get a reply so I'm guessing not. Hopefully Cristian can make one or I'll just wait it out. I've repaired both of mine so maybe they'll hold up, probably not though. I had JB quick and I don't think it's as strong as the slow curing stuff I normally use. Maybe if these fail I'll get some of that but I've also been reading 3M has some good stuff also. 3M usually = $$$ though so the adhesive is probably double the part.
Dave
Dave
Use CA, and build up the area with baking soda. Do it in small amounts as it will set up and be hard as rock, you'll have to grind it to get your taper back but it will be very strong. Ive built up missing parts of cf chassis this way and they last forever. The baking soda is very fine powder and fills the area very effectively.
