Like Tree3Likes
Old 03-13-2017, 09:09 PM   #16
vivo quevas's Avatar
Trader Rating: 18 (100%+)
The motor you can time and gear properly to fit your driving style.
You can buy any of the motors listed above and I have a box full to prove it. Every one of those motors are fast in the right hands. I borrowed a motor guy said it slow I re-timed it almost TQed with it. He was happy to get it back
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 03-14-2017, 08:12 AM   #17
eR1c's Avatar
...agreed, after trying many motors over the years I don't feel that one has that huge of an advantage over any other. Sure there may be small advantages, however the right setup and driver account for a lot more than the fast/best motor.
eR1c is offline   Reply With Quote
Old 03-14-2017, 09:41 AM   #18
DARKSIDE's Avatar
I call BS....
vivo quevas likes this.
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 03-14-2017, 12:17 PM   #19
DBM
I've been running the 17.5 and 21.5 Team Powers Actinium v2 motors for the last few months and have been very happy with them. They are definitely competitive with the other new crop of hot motors on the market. They are a high kv motor so i have found that they require a short gear ratio. I'm running ~4 teeth smaller of a pinion than i would have with my motiv m-code.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 03-14-2017, 02:03 PM   #20
One good motor is all you need, and not ten.... Work on your setup, and lightening your drivetrain if possible, on top of watching your battery's health.....
bertrandsv87 is offline   Reply With Quote
Old 03-14-2017, 02:05 PM   #21
traumajunkie's Avatar
I have been really impressed with the Savox's motor line...
"If I am not jump starting your heart with a car battery I am racing"
traumajunkie is offline   Reply With Quote
Old 03-14-2017, 08:57 PM   #22
I am very interested in the information in this thread, keep it coming. I have been using a LRP but I feel like it has some short comings compared to the newer motors coming out.
djgrom is offline   Reply With Quote
Old 03-14-2017, 09:27 PM   #23
nexxus's Avatar
Trader Rating: 301 (100%+)
Are we talking about the same motor? I have an Actinium V2 with a 12.3 rotor, and I have to gear it 3-4 teeth higher than what I gear my Monster 21.5 Certified at. It doesn't have a lot of timing, max 44 degrees endbell when on the motor checker
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 03-15-2017, 01:03 AM   #24
DBM
Interesting, mine gives the best results on the dyno with the timing set to 47 degrees. At 48, amp draw was 8 amps. At 47, it is 6.1 amps. 12.5mm rotor. 47 degrees is what my motor checker shows. The end bell shows 43 degrees.
Old 03-15-2017, 01:32 AM   #25
nexxus's Avatar
That is really strange, at max endbell timing (past 60) on the can mine only goes to around 44 on the motor checker, at 50 endbell it was 37. The motor was very low rpm wise but could take a fair bit of gearing. Maybe the 21.5 behaves differently
Old 03-15-2017, 01:52 AM   #26
DBM
Iirc, on the dyno with a load on it, this Actinium v2 had ~10% higher kv but ~10% lower torque than an R1 V15. At the track, i end up gearing ~10% shorter than the V15 and still have the same or more speed on the straight.
Old 03-15-2017, 02:34 AM   #27
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Come on bertrandsv87
How is your driving ?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 03-15-2017, 02:25 PM   #28
Talking
Can't drive in the snow.....lol....
If the motor pulls 8amps at 48 degrees, it must turn alot more rpms than 47 degrees...
I always look for a minimum of 3350rpm , no matter the amp draw, but if it exceeds 8amps, then something else is wrong.... Remember to decrease your car's f/r toe settings with higher motor amp readings: zero toe everywhere to go faster....
Old 03-15-2017, 05:11 PM   #29
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
So you run 0 toe in the rear? lol
PIIHB! likes this.
Dan is offline   Reply With Quote
Old 03-15-2017, 06:22 PM   #30
howardcano's Avatar
Trader Rating: 35 (100%+)
He's not the only one. I run zero toe in all classes.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
