Like Tree84Likes
Old 02-26-2017, 02:05 PM   #16
fyrstormer's Avatar
My first RWD touring car (the Porsche shown above) was initially configured with a TA-06 one-way pulley installed backwards on the front gearbox, to allow four-wheel braking instead of freewheeling. The braking was significantly improved as you'd expect, and it no longer suffered from snap-oversteer when braking, but the acceleration was still terrible and the handling was very squirrelly when applying any power at all. It also shredded the Vaterra 31mm rear tires I used in no time. It's possible those HPI tires would help (I think they have them as wide as 34mm?), but ONLY if they're made out of a properly-sticky compound -- S-compound isn't good enough, and D- and M-compounds are a complete waste of time. Pro compound is the only thing that will come close to offering enough traction with only two drive wheels.
Hawk6 likes this.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 02-27-2017, 12:12 AM   #17
ErikJan's Avatar
In Germany some racers around the Erftarena just started the KÄFER FUN CUP. RWD based on a standard Tamiya TT chassis, kit tyres, 17.5T and a Beetle body. (http://www.rccar-online.de/verein_lo..._reglement.pdf)
Maybe some of the racers can share their experience here.
Hawk6 likes this.
ErikJan is offline   Reply With Quote
Old 02-27-2017, 01:58 AM   #18
I was experimenting with RWD in rally few years ago - it handled pretty well, was not that much sensitive to power - on tarmac it was almost impossible to spin under power (15,5t motor).. It all depends on weight distribution and settings, RWD is not as forgiving as AWD. Yes, braking was problem, it takes much longer to stop, but if you didnt hit brakes in the middle of corner, it wasnt problem to keep it in line
On high traction surface, TC with removed front may work, at least with weaker motors - most recent F1s have lot of weight on front axle, with inline battery and motor in front of axle.. On lower traction, you need more weight on rear end
Lonestar and Hawk6 like this.
Papi is offline   Reply With Quote
Old 02-27-2017, 06:00 AM   #19
niznai's Avatar
Originally Posted by Hawk6 View Post
Shouldn't there be more RC cars that are laid out similar to full size race cars?
Why should it?
Regardless.
Grip doesn't work in your favour, just like it doesn't in most of the situations you mentioned.
You don't have enough grip at the front and you don't have enough grip at the back, that's why you need both.
If AWD did not come with a serious weight penalty in real life scale, I am sure you'd see most of those cars you mention turning to AWD. In fact real cars which are more powerful and faster than the racing categories you mentioned (think supercars), actually use AWD. Why do you think that is?
But daft as it sounds there is a class like that, and it is big. Just not where you are, otherwise you would have known:
https://www.youtube.com/watch?v=32PskkNB-Uk&t=219s
Hawk6 likes this.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is online now   Reply With Quote
Old 02-27-2017, 06:41 AM   #20
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
the 1/5th scale gas cars work well but they also have 4 wheel disc brakes and a hefty weight,m 1/10th would be tough , e few years ago there was a class 2wd 235mm 1/10th scale nitro with a slipper rear diff but the class died off
Old 02-27-2017, 06:57 AM   #21
hotrod87's Avatar
Trader Rating: 252 (100%+)
We had Bolink back in the day.
RWD, 4 Wheel Independent Susp. Onroad Cards - Why Not?, Why?, How?-vintage-bolink-invader-oval-car-racer_1_d7800b82d8a86b44e4ce31025380ae0b.jpg
RWD, 4 Wheel Independent Susp. Onroad Cards - Why Not?, Why?, How?-vintage-bolink-invader-oval-car-racer_1_d7800b82d8a86b44e4ce31025380ae0b-1-.jpg
Lonestar and 1/8 IC Fan like this.
ON A WALKABOUT AS OF 7/27/17
hotrod87 is offline   Reply With Quote
Old 02-27-2017, 07:21 AM   #22
1/8 IC Fan's Avatar
Trader Rating: 46 (100%+)
We did have those cars!
Serpent Quattro 2wd, Impact 2wd, Tenforce, Yokomo Super Scale etc. They all went the way of the dinosaur. Lastly as for 1:8 2wd, the pan cars were easier to drive than the "fully" 2wd cars. The Tenforce came at the wrong time, we were running Pro10 and Wide (4wd buggy based) Touring Cars (pre-TA01 / YR4). The Impacts just had a loss of participation, Delta had the Fireball (awesome, just too finicky).
I know I am referring to both Nitro 1/8 & 1/10 as well as Electric 1/10. But it all coincides with the decline of 2wd onroad in the 90's.
People found the 4wd cars easier to drive, and as such the 2wd cars suffered, just look at f1, the tried to bring it back in narrow form, and now what, it died off again.
There was nothing wrong with the Tenforce or Yokomo Super Scale cars, they handled great, just no one was buying them anymore.
The F103GT is an awesome platform, as you can just use old TC tires and run some really hot laps, not to mention the great support still available for the F103 based cars.
Lonestar likes this.
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 02-27-2017, 07:30 AM   #23
fox88gt's Avatar
Team Associated tried this 20 years ago with the RC10DS (Dual Sport). It was a cool car that used the aluminum tub from an RC10 buggy/stadium truck with short shocks, short arms, and on-road wheels/tires/body. It was a neat concept but never caught on.
I think its a great idea though. If we can make F1 cars handle (with 2WD, rubber tires, and a solid axle in a pan car) there's no reason that a fully independent touring car can't be made to handle with 2WD.
I quit 17.5 sedan years ago because it was too much of a point-and-shoot style of driving for my taste. F1 and Mini are more fun to drive. You have to modulate throttle inputs, brakes, and steering. Sometimes you have more power than you can put down. It puts the emphasis on the driving and the setup. It avoids the touring car battery and motor wars too.
"When you no longer go for a gap, you are no longer a racing driver..." Ayrton Senna
"I dont like being overtaken. It's a sign of weakness." Jeremy Clarkson
"Leave me alone....I know what I'm doing." Kimi Raikkonen
I don't always race RC....but when I do....I prefer road course.
fox88gt is offline   Reply With Quote
Old 02-27-2017, 07:33 AM   #24
niznai's Avatar
Originally Posted by Marcos.J View Post
a hefty weight
Exactly.
That means grip.
Team Greasy Weasel
Old 02-27-2017, 08:24 AM   #25
Send a message via AIM to Nerobro
I think the reason RWD hasn't stuck around on-road is simple. 4wd is easier to drive. Maybe, just maybe, it's a braking thing. But I think the tendency to push, and greater all up weight all contribute to a car that's easier to drive.
The "desire for push" is one reason why spools are "the hot ticket" up front.
We lack IRS, but pan cars are still a thing. Those are rwd.
RWD with IRS is also a thing for dirt oval cars. And a lot of the drift cars are IRS and RWD.
Originally Posted by niznai View Post
Exactly.
That means grip.
Grip falls off with weight. Weight means slower responses to things like slides (this is not a bad thing for small cars..).
Nerobro is online now   Reply With Quote
Old 02-27-2017, 01:59 PM   #26
It is a great idea, but the cars would be very hard to drive....
bertrandsv87 is offline   Reply With Quote
Old 02-27-2017, 02:09 PM   #27
It's my personal opinion that the DS was the best all around parking lot/subdivision street car of all time. It was simple and fun and has enough suspension that it can run where pan cars can't. I like that it doesn't have the complexity of a touring car but you could still use realistic bodies with it. On a smooth asphalt or carpet track, it wouldn't stand a chance against any other car classes but a bunch of them together was a riot.
Hawk6 likes this.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-27-2017, 02:29 PM   #28
With the "no weight limit" for FWD cars... a no weight limit RWD car might do some stomping of the 4wd crowd...
Old 02-27-2017, 07:34 PM   #29
Hawk6's Avatar
Trader Rating: 50 (100%+)
I started thinking about all of this when I saw Tamiya's F103GT Nissan Launch car:
I started reading about the full size car and found out it is FRONT wheel drive. So, the Tamiya model is a low-tech (F103GT) RWD model of a high tech FWD car, and I just thought that was kinda odd.
(I suppose I could buy the Tamiya TA06 chassis and disconnect the REAR drivetrain, and plop the Nissan Launch body on it. Then I'd have a scale FWD car).
I applaud Tamiya for their variety of RC cars like their FWD and RWD selection of M chassis cars, the F103GT platform, etc.
I know for organized racing, we need a limited number of classes, so a rwd independent suspension car will likely never be the norm but it's interesting to think about. Thanks for the replies all.
Hawk6 is offline   Reply With Quote
Old 02-27-2017, 07:38 PM   #30
Hawk6's Avatar
This is right along with my line of thinking. Thanks.
