Like Tree84Likes
Old 03-11-2017, 03:23 PM   #136
fyrstormer's Avatar
Originally Posted by Papi View Post
You could emulate low current outputs of NiMH with resistor - I found 140W 0.15ohm resistor, which would limit maximum current to about 50A - as I rekember, this was maximum current of cheaper stickpacks
That resistor would overheat incredibly fast.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 03-11-2017, 03:46 PM   #137
Originally Posted by Jorge T View Post
that Yokomo on asphalt with GT-R CRC tires and 17.5 w/2S.. Hmmm...handful of fun!
My RC10 DS was a blast and would keep up with the TA02 cars, but then the HPI RS4 came out...
The original HPI RS4 with the belt drive in front and a 64P version of the Stealth gearbox in the back? It was a great car. I had one. It was a huge step forward. Although it didn't take long for the RS4 Pro to be released, which was the same car with dual belts instead of the Stealth in the back.
Lipo?
Brushless??
I'm still running Sanyo NiCds with a mechanical speed control.
FrostyDude is offline   Reply With Quote
Old 03-11-2017, 08:27 PM   #138
Man, first thing, I'm happy I still remember my rctech password, haven't been here since NorCal Hobbies moved to San Jose.
I landed in this thread searching for a RWD drift car after finding myself in a deep Google rabbit hole about how the best Japanese rc drifters still use a 4WD counter steer (rear wheels overdrive the front wheels) in conjunction WITH a one-way diff/pulley. I thought, "Isn't this this just RWD at its core?" There is no way power is ever getting to the front wheels if the rear ratio is lower than the front--the one-way is always freewheeling.
I'm old enough to have raced 10th scale pan cars, and the reason we made those work was with rear tire widths almost 40% wider than the fronts, and liberal application of Paragon at the rears and just a pencil line of that same stuff in the fronts.
F1 was actually bearable with foams, even though I had a good few years racing rubber outdoor F1 with the RCFIA group, I never really enjoyed it as much as the foam tire days.
Hawk6 likes this.
TwoWheel is offline   Reply With Quote
Old 03-11-2017, 08:45 PM   #139
But back to the topic of RWD touring, after a few failed attempts at converting a few platforms, the main issue I've had, and as other folks have brought up, is off-power/braking oversteer, unless there is a way to have front wheel braking (several ideas I've seen in this thread have got me thinking at another RWD conversion attempt.
Historically speaking, we obviously can make RWD platforms work without front brakes, but the similarities in all the classes that have stuck around for a while have always been rear tires wider than the front and the ability to bias a lot of weight to the rear--buggies, pan cars.
The only thing I can think of that would come close, is the M-06, but with the ability to place the battery across the chassis instead of lengthwise.
That Yokomo YD-2 would be perfect if it had the option to put the motor behind the rear axle.
Old 03-11-2017, 11:14 PM   #140
Unless you're running mod, front brakes is only for emergency stops....
bertrandsv87 is offline   Reply With Quote
Old 03-12-2017, 12:35 AM   #141
I guess my main question would about RWD touring would be...
Why Bother? A RWD pan car is better in every possible way. The only downside to a pan car is you need a smooth track. Nowadays they are usually only run with 1S, however in the days of NiCd and NiMh batteries they were run with 6 cells like most other 1/10 scale cars. The current 1/10 scale pan cars can all be run with 2S and with that much power and foam tires they will be faster than 4WD touring cars.
You can even get rubber tires if you want. Although I would stay with foam.
wtcc likes this.
Lipo?
Brushless??
Old 03-12-2017, 03:42 AM   #142
SWTour's Avatar
As a 2c Pan Car racer, I can say there are several downsides vs a tc type car. (and I LOVE Pan Cars)
I do HATE 1c PAN CARS (waste of time IMHO) the 1c itself...hate it.
But TIRES (foam) get old (caps) are now hard to get, and (rubber) is gaining popularity because they last, don't have to be trued down to 2.05 from 2.4-2.5" work on multiple surfaces...kinda, but are kinda pricey.
Where as you can get SPEC TC tires for less than 1/2 the price, so long as the 2wd RWD TC uses standard TC hexes.
My fear is a RWD TC would handle like CRAP, but I for 1 would like to try one at a few places...and one of those places would be on an OVAL track.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 03-12-2017, 04:59 AM   #143
Well, NiMH packs heated too That's why you need 100W+ resistor and proper cooling. It would heat less than mechanical controler. I'm more afraid of voltage drop.
Anyway, what sort of motor are you using? In M06 thread people drive 15,5t succesfully. And I didn't have problems with traction on 15,5 with 10:1 gearing on gravel. Actually, I had problems to make it turn in low speed, that's why I abadoned rear motor concept.
Papi is offline   Reply With Quote
Old 03-12-2017, 05:37 AM   #144
I will make one statement about WGT-R rubber vs USGT rubber or TC rubber. Yes they cost twice as much but they are competitive almost 4 times longer. This is based on road course racing. I run F1, WGT-R (same tire) and USGT. We have a healthy core of TC racers and based on observation they go through tires the fastest. A USGT tire slows down a bunch due to stretch, not surface wear.
Maybe I will pull the shaft on my TC and see how it works.
liljohn1064 likes this.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 03-12-2017, 06:07 AM   #145
fyrstormer's Avatar
I've been using Holmes Hobbies TrailMaster Sport 27-turn disposable motors. Holmes Hobbies specs those motors with a ball bearing on the output side of the motor, so there is no bushing to wear out. You can run the motor until the brushes are completely gone and there still won't be any slop around the motor spindle. They are not powerful motors, which is precisely why I use them for certain applications. I have one in my FWD rally car, and I also tried one in my RWD touring car. I'm thinking if I do it again, I might get a proper rock-crawler motor (35 turns or higher) because a rebuildable motor will weigh more than a disposable motor, and I'll use astronomically high gearing (maybe even higher than 1:1) to get lots of speed out of it.
Old 03-12-2017, 09:40 AM   #146
Let me clarify and say I am NOT against independent suspension. I'm only saying that the way touring cars implement it with their skinny tires and identical width front and rear tracks is weak.
I would be all for a 1/10 scale electric version of a 1/8 scale nitro car like this. It would be awesome in either 4WD or RWD versions.
Hawk6 likes this.
Lipo?
Brushless??
Old 03-12-2017, 10:11 AM   #147
In my original post, I do state that we have already had successful RWD programs without any need for additional braking on the front, and pan car was one of them.
One thing that is quite obvious to me is that the ratio in width between front and rear wheels is becoming closer and closer to 1:1, with the new Yokomo RWD touring and Tamiya M-06 platforms exactly at 1:1.
Now, when we were running foams, the rears were definitely more than a marginal width wider than the fronts. With the current trend of rubber tires WGT, F1, etc, that has changed. What also has changed is that the rear pod setup and the "suspension" that goes along with it has become softer and softer, with arguably more adjustment besides splashing some oil on a friction plate to control damping in all directions.
I personally feel that the margin in chassis setup to get foam tires to work was wider. With rubber tires, chassis tuning and weight balance was much more key, and the window for a good setup is much narrower. But I don't want to derail the discussion into a foam vs. rubber argument.
You can find me at the folllowing sites:
twowheel at rcracing.com
FuriousFlip at ultimaterc.com
K.O.M. at rccrawler.com
TW@ at vwvortex.com
Old 03-12-2017, 06:18 PM   #148
Hawk6's Avatar
Trader Rating: 50 (100%+)
My work in progress, a Tamiya TA06, took out 2 oz (62 grams) of weight by removing the front diff, dogbones, belts, pulleys. I know it only has a silver can motor in it, but I figured I'd start small before investing in more powerful and expensive power.
The rear tires are HPI vintage 31mm wide. They don't feel real soft, but I will try them.
I need to finish an experimental body for this experimental chassis, so stay tuned.
It obviously will not keep up with racing touring cars with the silver can, but it will (hopefully) make a fun test bed for me.
RWD, 4 Wheel Independent Susp. Onroad Cards - Why Not?, Why?, How?-ta06-reduced.jpg
Lonestar, rccartips and kwkride like this.
Hawk6 is offline   Reply With Quote
Old 03-13-2017, 01:16 PM   #149
Send a message via AIM to Nerobro
I think 62g isn't enough to really swing this around. We'd need to be talking like a 30% weight reduction. Enough to cover up for lap time inconsistancy.
Hmmpf.
Nerobro is online now   Reply With Quote
Old 03-13-2017, 02:36 PM   #150
Hawk6's Avatar
Hmmpf.
I don't disagree. I was basically just reporting what the weight of the removed components was. Most of that weight (not surprisingly) was the front diff.
I suppose lightweight electronics would help a bit, but not 30%. A 1 cell battery pack would help a bunch. Then weight distribution stuff like putting the motor behind the rear axle, etc. but that is beyond my capabilities.
