F104W Handling..new to F1 class
I just had my Tamiya F104W built. It has a Castle SVC Sidewinder ESC and a Castle 5700KV brushless motor. It has the stock rubber tires.
Here's my problem. The slightest throttle will make the car spin in circles, while going straight and I give more throttle in spins out, and lastly even at very slow speeds it will spin out while turning...
any help would be greatly appreciated
what do you mean by 'stock rubber tire'?
I used front medium / rear hard compound on asphalt with 75 degree and it works fine. I'm talking about F104x1. So if you use the same compound under the same weather & ground you should be good specially since you have 'w' version. I used ride front soft / ride rear medium, same ground with 85 degree the car keeps spinning.
So I would check the compound of tire first and then check the diff. The tight diff can cause it. For me, I start loose and then keep tightening by 45 degree until the diff doesn't 'slip' when you pull the trigger from total stop.
The stock tires for the F104W are pretty horrible...they harken back to the F103 days. If you get a set of the normal F104 rims and tires you will have better grip BUT the front end will be a lot wider than the rear. I saw 1 company make a set of aftermarket rubber tires for the F104W but I don't know if they still do or if they worked well or not. You would probably be better off with foam tires...but not sure if they are making them for the F104W or not.
Are you planning on racing or just driving around the neighborhood?
a few guys have just purchased F1's , were going to start an F1 class here in Northern California.
thanks for you reply
the stock tires that came with the kit.
That's great! There are a few things your group is going to need to decide upon at some point...the big one being tires. Most groups within the US run rubber tires only classes because it keeps the class looking scale. If you mix foams and rubber tires then you may run into a problem with foam dominating the class if the grip is good. If the grip is bad then the rubber tires are going to dominate. Then you have overall width...there's 3 widths in F1, 180mm, 190mm, and 200mm. The F104W is 200mm while a standard F104 is 180mm. I believe the 3Racing FGX is 190mm...when rules were still pretty loose guys were widening the F104 to 190mm so that eventually became the rule that most places use. While it is cool to just run whatever when the group is still small...that's how we started too...if you don't plan for what to do when the group gets bigger that can cause problems later on.
What part of California are you in?
Diff spur gear
Wow...way to bring back a 2 year old thread
