No Go!
No Go!
Hello all
I have a HPI sprint 2 which i have installed a futaba MC230cr in and when i switch it on all it does is beep, i can steer but no throttle. Now if i plug it into my steering channel it works but throttle is on steering! and the trigger does not move the servo. I have tried holding the set button but to no outcome. Can anybody help?
Iam using
1 x HPI Sprint 2
1 x Futaba MC230
1 x Hitec HS-525bb servo
1 x KO EX-10 Helios
Thanks in advance
Iam using
1 x HPI Sprint 2
1 x Futaba MC230
1 x KO EX-10 Helios
Thanks in advance
that esc was built for drag racing so it doesnt give you the luxury of steering and throttle......
Na only joken you probably have to set it up. Did it come with any instructions? if it did it should tell you how to set it up
Originally Posted by Brett.w
Hello all
Iam using
1 x HPI Sprint 2
1 x Futaba MC230
1 x KO EX-10 Helios
Thanks in advance
Iam using
1 x HPI Sprint 2
1 x Futaba MC230
1 x KO EX-10 Helios
Thanks in advance
After closer inspection i had found that one of the reciever plugs were bent and i now fixed the problem
Thanks for your guys help
