Old 02-11-2017, 07:55 PM   #1
pullstarter's Avatar
Trader Rating: 14 (100%+)
Default Issues with storage charge and discharging on my Muchmore Hybrid Pros
Hey guys,
After last meet I had a couple of packs that were charged and not used so I decided to put them on the Muchmore Hybrid Pro chargers that I use and put them on storage charge.
After plugging them in and hitting go on storage cycle the charger starts up as per normal, the read out for storage charge comes up on the screen but then it just idles. Timer is going but the discharge amps doesn't move off zero and the mah read out stays on zero. Wtf is going on here? This is happening on both my chargers with 3 different brands of packs which all did storage charge quite happily in the past.
Both chargers also does the same thing if you use the discharge cycle, discharge screen comes up, timer starts, but readout on the discharge amps is 0 as is the mah discharge readout.
Any help would be greatly appreciated.
Cheers
Simon
pullstarter is offline   Reply With Quote
Old 02-12-2017, 11:24 PM   #2
I also have the same charger with the exact same problem.Will be interesting see if an anyone has any suggestions to cure the problem.I don't believe there is anyway to update the firmware.
Mi5Speed is offline   Reply With Quote
Old 02-12-2017, 11:55 PM   #3
I've been looking for firmware upgrades too but like you say, I don't think there's a way to do it?
Is yours still charging fine? Mine seems to, normal charge and balance charge is fine.
Will keep you in the loop.
