Old 02-10-2017, 05:21 AM   #1
Default !!! Is there a GFX Turbo 35 Alternative for checking discharge voltage?
Is there really no alternative to the old Turbo 35 for accurately checking battery discharge voltage? I mean for the love of Pete! Trying or find one takes and act of congress.
kobiwan is offline   Reply With Quote
Old 02-10-2017, 05:36 AM   #2
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Will a turbo35 do same test as a gfx ?
If so I have a old turbo35 in working order I will sell
jlfx car audio is offline   Reply With Quote
Old 02-10-2017, 05:39 AM   #3
vivo quevas's Avatar
Trader Rating: 18 (100%+)
An Icharger will check discharge voltage 306d and above.
!!! Is there a GFX Turbo 35 Alternative for checking discharge voltage?-20150712_170019.jpg
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 02-10-2017, 05:43 AM   #4
RIP Motorsports teased this a month ago: https://www.facebook.com/RIPmotorspo...MELINE&fref=nf
We don't know anything about it's performance yet.
There was also something called a RMS-1 Battery Dumper, but don't know if it did average voltage.
_______________________________
Phil Matthews
#SMC #WeAreAE #TotalRC #Sanwa
pilmat is offline   Reply With Quote
Old 02-10-2017, 06:03 AM   #5
Negative. It doesn't give solid #s cause of its gradual ramping current you can't accurately get voltage #s
Old 02-10-2017, 06:25 AM   #6
Not sure. I'm not sure what the difference is.
Does anyone know if there is a difference?
Old 02-10-2017, 06:42 AM   #7
PM sent
Old 02-10-2017, 08:40 AM   #8
jak43's Avatar
Trader Rating: 15 (100%+)
A turbo 35 or even an turbo 30 will still discharge and give you the numbers needed. They go for around $40 or less on ebay. The GFX will graph, but on a turbo 35 you can watch the discharge, write down the data and make your own graph or table. You don't even need one that is lipo capable if you watch the battery and don't discharge it down too far or charge with it. Gfx's go for over $150 on ebay.
jak43 is offline   Reply With Quote
Old 02-10-2017, 09:01 AM   #9
I didn't see any on eBay. At least not a GFX.
Old 02-10-2017, 09:17 AM   #10
Aaron P's Avatar
Tekin DIS-350 discharger, if you can find one. It will only tell you the whole pack, not each cell, but has programmable discharge rate and cut off voltage. It also has 3 discharge profiles...linear, pulse, or step (supposed to simulate driving conditions) and gives IR measurement
I'm never letting go of mine.
Proud Privateer
Aaron P is offline   Reply With Quote
Old 02-10-2017, 09:46 AM   #11
jak43's Avatar
They had one earlier in the week. I was watching it but did not want to pay that much. There is also a Turbodyno on their now.
Old 02-10-2017, 11:31 AM   #12
IndyRC_Racer's Avatar
I have an older Duratrax Ice charger that will discharge up to 10amps. I know you can switch to a graph display as it is discharging and could record time/voltage while watching it. If I recall correctly, you can view the most recent discharge cycle. I don't recall if you can save any of that info in the charger itself.
This charger doesn't have a balancing port built into it, so you wouldn't be able to record any info about individual cells.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 02-10-2017, 11:54 AM   #13
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
I used the prototype at the Snowbirds and it was pretty awesome!!!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-10-2017, 01:16 PM   #14
Step discharge seems to be the way to go.....
bertrandsv87 is offline   Reply With Quote
Old 02-10-2017, 02:03 PM   #15
Not if you use a 30 amp discharge bank I take readings every minute for 6 minutes and I get good information. I'm sorry I should have wrote that down in my original post.
