Old 02-10-2017, 03:20 AM   #1
Default pan car set up stations valid for F1 cars?
Hi,
I am thinking about buying a set up station as the one that I own has a lot of slope and it is everything but accurate. At the moment I am using a TC one for the F1 and I do not have for my 12th car and I was wondering if the pan car ones such as Hudy 109405 or the Arrowmax 170043 will work with both cars? or do i need two units? one for the f1 and another one for the 12th car
Javier
jimjav is offline   Reply With Quote
Old 02-10-2017, 06:43 AM   #2
G-rem's Avatar
Hi Javier,
the pan car station won't fit the F1 (and vice-versa). The F1 setup station is in fact a normal touring setup station with specific spacer for the front wheels, that's it.
Moreover, the bearings of the front hub of a pan car are smaller than the ones for a F1.
Regards,
G-rem
G-rem is offline   Reply With Quote
Old 02-10-2017, 07:03 AM   #3
Thanks G-rem,
I was expecting that answer but i wanted to know it for sure.
I have been using on my F1 my old TC set up but it has never been a good one, so I as I need a new one I was hopping to find that I can buy the pan car one and only need one on my pit bag.
Cheers
javier
Old 02-10-2017, 09:08 AM   #4
Moogumby's Avatar
Trader Rating: 30 (100%+)
Which spacer is needed or is it depending on your car?
Moogumby is offline   Reply With Quote
Old 02-10-2017, 09:23 AM   #5
These, as long as your car uses 5x10 mm bearings
https://www.hudy.net/xhudy/products/...6&kategoria=64
They are 10-12$ or so.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 02-10-2017, 07:03 PM   #6
Just use a couple of old bearings ... no need to fork out $10 for the adapters
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 02-10-2017, 07:35 PM   #7
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
I regret getting my Hudy F1 setup station when I already have the TC setup station.
Ironically, what is more accurate is the Turnigy Trackstar 1/10-1/12 setup station. The quality isn't any where near the Hudy of course, but you will get more accurate camber/toe readings. It has inserts that fit the F1 specific axles perfectly, instead of relying on the stupid spacer setup of the Hudy.
https://hobbyking.com/en_us/tracksta...up-system.html
Dan is offline   Reply With Quote
Old 02-10-2017, 08:13 PM   #8
you can make the adaptors on a 3d printer for less than the 10.00 from Hudy. Mine work fine. (TC set-up station).
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 02-11-2017, 04:03 PM   #9
Madulla's Avatar
I use the Hudy 12 scale setup station. Just got bearings that fit in the 12 scale adaptors that fit the F1 axle. I can't remember the size, but had to find imperial ones that are really close in metric size. Then I use extra wheel bearings on the axle as a spacer to allow the setup triangle to screw on tight.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 02-12-2017, 04:04 AM   #10
Can you maesure them??
That what was I was thinking
