Old 02-11-2017, 10:26 PM   #16
EddieO's Avatar
R/C Tech Charter Subscriber
Originally Posted by Boostinswifty38 View Post
I cannot imagine a rubber tc would have issues as rubber insulates and doesn't conduct.
Heh, its FOAM Rubber on a pan car...
Being on rubber tires doesn't stop static from building up....hence why you can drag your rubber shoes on the carpet and then get shocked....if rubber stopped static build up, people would not have to wear grounding straps when working on his end electronics either...
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 02-12-2017, 05:31 AM   #17
Later EddieO
Good example, Eddie.
davidl is offline   Reply With Quote
Old 02-12-2017, 05:47 AM   #18
ThrottleKing's Avatar
Trader Rating: 16 (100%+)
This is what I have used at the Hudy Race and at Birds. I had one hit last year at Birds and I got a nasty one at Cleveland this year. Since I started using it I have had no issues whatsoever. I spray it on a paper towel and rub down the chassis and the bottom of the arms. One application lasts for a couple days unless you have to use motor spray every run to clean the chassis. I just kept the towel in a freezer bag and cleaned the chassis with it.
https://www.grainger.com/product/SPRAYON-Anti-Static-Spray-1KRN8?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1KRN8_AS01?$smthumb$
Acts 2:21- And it shall come to pass, that whosoever shall call on the name of the Lord shall be saved.
ThrottleKing is offline   Reply With Quote
Old 02-12-2017, 05:50 AM   #19
I don't know why I cant get the link to post right but you can find it at Grainger.
