Like Tree12Likes
Old 05-11-2017, 09:24 PM   #46
#2. First run. TSM enabled
https://youtu.be/GiJvk7LfVv0
#2b. First run. TSM disabled
https://youtu.be/D1dRmnu5mvE
Billy Kelly is online now   Reply With Quote
Old 05-12-2017, 03:54 AM   #47
Originally Posted by Kregger View Post
What pinion and spur did it come with?
Stock gearing from the book is 21/70. They include a 25t pinion as the "speed gear". The 70t spur is only one listed.
Old 05-12-2017, 06:45 AM   #48
If my Math is correct, to get close to 3.6 you would need to be around a 47/60 in 48 pitch or 63/80 in 64p.
If 21/70 results in a 9.49 FDR, then the internal ratio is around 2.85, meaning your pinion:spur ratio needs to be around 1.26.
Will it take stand spur gears, or does it use special Traxxas only spurs?
0010 is offline   Reply With Quote
Old 05-12-2017, 07:18 AM   #49
Don't know yet on spur. The book only lists the 70t. Going to try to get a actual look at the gear over weekend. I had a feeling it was going to be geared wrong for any established race class. My USGT car is geared 35/69.
Old 05-12-2017, 02:05 PM   #50
jdob's Avatar
The spur gear is the kind that slides on over the drive shaft and is held in place by a pin...NOT a standard touring car type...TRA8357
jdob is offline   Reply With Quote
Old 05-12-2017, 02:06 PM   #51
jdob's Avatar
Clear Body - TRA8311
Old 05-12-2017, 02:11 PM   #52
Kregger's Avatar
According to the ratio calc I have its would be the same internal as a xo-1
Kregger is offline   Reply With Quote
Old 05-12-2017, 02:23 PM   #53
Kregger's Avatar
did you get that from the manual?
Old 05-12-2017, 02:26 PM   #54
jdob's Avatar
Yeah - we have the manual from the demo that Traxxas sent to the hobby shop.
Old 05-12-2017, 02:31 PM   #55
jdob's Avatar
If the internal ratio of 2.85 is correct, then with a 70 tooth spur you would have to have between 50-55 tooth pinion to be in VTA land...biggest you can put on by the manual is a 28.
The motor mount is similar to a Tamiya - a bunch of different holes to pick from depending on pinion.
Old 05-12-2017, 02:53 PM   #56
jdob's Avatar
The manual & exploded views are up now at the Traxxas website.
Old 05-12-2017, 05:15 PM   #57
Kregger's Avatar
Thanks,
page 25 has the internal at 2.85
Old 05-13-2017, 03:50 PM   #58
Got mine, haven't hardly gotten it out of it's box yet though.
Drift_Buggy likes this.
Ah, Biscuits...........
BJoe is offline   Reply With Quote
Old 05-13-2017, 03:52 PM   #59
Drift_Buggy's Avatar
Trader Rating: 20 (100%+)
Nice, must be pretty stocked.
Drift_Buggy is offline   Reply With Quote
Old 05-13-2017, 03:56 PM   #60
I've known the owner of the shop for years, he pulled one off to the side for me when it came in and called me. One of their employees installed the Bluetooth module for me as well while I was there.
