Old 01-31-2017, 09:40 PM   #1
Default Yeah Racing shock gear dampers, TRF and CVA, thoughts...
So after buying TRF dampers and seeing how they are manufactured, and build up. I decided to try some Yeah Racing shock gear dampers for almost 1/3 the price.
It's too early to tell with leakage and all, but as for machining quality, the YR damper bodies are on par. Also, YR's instructions say to use 1 clear o-ring like the TRFs. But actually provide 16! Tamiya provides only 4 I built the YR dampers with 2 o-rings each, so I have an extra 8 to rebuild at a later time. The shocks come with lots of different springs, albeit shorter than Tamiya springs, I guess you would just need to screw the shock collar lower to achieve the same settings. I ended up using my white Tamiya springs (I think they are the same hardness as the yellows). Ball studs, extra e-clips, 1 extra shock cap and damper end are included (in case of crash) and the urethane seals seem to be just as good. I mean how is it Tamiya can charge $60+ for TRF dampers if YR is charging like $20 (US dollars) for an almost identical product?
Anyway I am pretty impressed with the value. The one thing that might be worth mentioning is the pistons are clearly better than the CVA tree parts, but not quite as thick as the white plastic pistons that Tamiya has. I ended up using my extra Tamiya 2hole white TRF pistons, and the included YR 300cst fluid. I got the 55mm ones, but they come in 60mm too.
I have yet to use them, but they feel smoooooth. I will try them on both of my Tamiya cars.
And here I thought the CVA dampers weren't that bad. They really arent, just the pistons suck and the shock collars are silly annoying. I used 80wt with 2 hole pistons to get the same damping as 40wt with 3 hole using the white TRF pistons. Now I've got like 5 sets of YR pistons rebuild my CVAs with now. All I need is another car to use them on.
4roller is offline   Reply With Quote
Old 01-31-2017, 10:33 PM   #2
Interesting info
Have you tried compatibility with TRF shocks? Problem of these cheap shocks is that it's sometimes hard to find spare parts (mainly o-rings and rod guides).. It would be nice if those fit from Tamiya
Papi is offline   Reply With Quote
Old 02-01-2017, 02:05 AM   #3
Identical, the o-rings, pistons, rod guides, shafts, top cap insert, shaft end, urethane bladder, they are a perfect fit with Tamiya.
I am going out on a limb here, but maybe even the thread pitch is the same. I think they're are suppose to be a replica. Maybe even manufactured in the same factory, just branded different.
The shock cap, pistons, and shaft end, spring cup aren't the same design but similar and fit with TRF/CVA dampers. The plastic might be a little different too, everything is interchangeable with Tamiya parts.
Originally Posted by Papi View Post
Interesting info
Old 02-01-2017, 03:44 AM   #4
Lonestar's Avatar
Only time/testing will tell. Keep us posted.
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 02-04-2017, 05:24 PM   #5
So putting the yeah racing damper bodies beside TRF 55mm damper bodies and shafts, you can tell they are identical.
From now on, I'll be purchasing the Yeah Racing dampers. No leaks so far. It's been a week.
Old 02-04-2017, 06:13 PM   #6
gigaplex's Avatar
The tapering on the end caps looks a bit more pronounced on the YR shocks, but they do look like a pretty convincing copy. I might try a set on one of my minis.
gigaplex is offline   Reply With Quote
Old 02-04-2017, 07:33 PM   #7
For all intents and purposes, they are functionally equivalent. The measurements of spring cups are identical. The shaft ends and top caps are made of a harder (britler) plastic material. But you can replace pieces with Tamiya bits as needed.
I think YR also make a 50mm damper for minis.
Old 02-04-2017, 08:17 PM   #8
I've been using Yeah Racing adjustable dampers basically since they released them for drifting and can testify that after years of use they hold up well. I've only ever had 1 leak at the bottom o-rings, but after replacing the o-ring it's good as new. The springs they come with are the weak point, IMO anyways. I'm sure racing puts more stress and wear on them, but these are worth every penny and then some.
wareagle84 is offline   Reply With Quote
Old 02-04-2017, 09:02 PM   #9
RacerX20L's Avatar
Default TC 6.1 replacements?
I saw these on ebay and have wondered if they would make a good replacement or spare set for a Team Associated TC 6.1
RacerX20L is offline   Reply With Quote
Old 02-05-2017, 01:05 AM   #10
walrusjon's Avatar
Thanks for info, would love to try one on later soon.
Tamiya M06, Xray X1 2015, Xray T4 2017,Tamiya TB EVO V Exotek V2,Tamiya TB 03 VDS, Tamiya TB 01, Xpress Road Runner Pro, Tamiya Falcon, Kyosho Salute, Yokomo YZ834B Dog Fighter, Tamiya Grasshopper
walrusjon is offline   Reply With Quote
