Old 01-28-2017, 04:05 AM   #1
Questions?? Stupid Question: Touring Car chassis with LeMans style body? Possible?
So I was interested in Pan cars because of their aero... However the over simplistic design doesn't interest me very much.
So I began to wonder if it would be possible to combine the two: To mount a Lemans style body over a 1/10 touring car chassis? Now I could see that upper shock mount would be in the way, but I have noticed that some people have been able to lay the shocks down flat and connected by a bell crank and push rod.
I kind of have my heart set on a 1988 Nissan R88C Group C Prototype... But I could compromise with a Mazda 787B.
So what chassis would I need to make this happen? Would it be possible on something from Tamiya like the TRF419 or TB6 Evo?
Though I think those would be a big jump for me... considering that my onroad car is a very outdated TA02... Though with a carbon chassis and aluminium everything... getting something top tier may be foolish... may be wise... not sure
KoroKoro is offline   Reply With Quote
Old 01-28-2017, 04:22 AM   #2
gigaplex's Avatar
Awesomatix or Serpent 4X are probably the most likely chassis that will fit. Some of the Tamiya chassis (such as TA05) have an IFS suspension option on front that may be sufficient.
gigaplex is offline   Reply With Quote
Old 01-28-2017, 04:25 AM   #3
SteveM's Avatar
Trader Rating: 134 (100%+)
You may want to consider getting a newer 4wd sedan chassis and almost any of the ones sold today should be OK.
McAllister Racing make some very nice bodies that might interest you.
http://mcallisterracing.com/
SteveM is offline   Reply With Quote
Old 01-28-2017, 04:32 AM   #4
1spunspur's Avatar
Not a stupid question. I've thought of it myself.
I don't think it's possible, seeing how the suspension is built onto the diff. I think the diff. alone would prevent you from mounting such a body.
P./
1spunspur is offline   Reply With Quote
Old 01-28-2017, 05:02 AM   #5
The TA05 + IFS looks good.
What about a TA06 or TA07? Will they be making an IFS kit and carbon chassis deck plates too? If so, TA07 looks good, right?
I'm worried too that the diff would get in the way... though I am willing to make compromises. Its possible to deform a lexan body with a heat gun right?
I had a look at mcallisters site... good that he does GT prototype stuff for 1/10th. Can he do custom orders? Or would it be better to try and find something from a pre-existing kit?
Old 01-28-2017, 05:11 AM   #6
gigaplex's Avatar
That picture actually is a TA06, so yes to that option. I don't think the TA07 bulkheads are compatible with an IFS suspension though. It's possible they might eventually do a version 2 that does, but don't hold your breath.
If you're willing to compromise on the body, Frewer Racing did a Porsche Le Mans shell back in the day (around 2000?) with a shock tower bulge. They'd be pretty rare by now though.
Old 01-28-2017, 05:29 AM   #7
Trader Rating: 30 (97%+)
I have tried to mount the Tamiya group C bodies on a touring car, and unfortunately could not fit them on any, wheel base is too long, and even with ifs suspension, they do not sit low enough. Including the awesomatrix. If you want a 4wd group c car, with proper Tamiya body, the only chassis option is a F201 from Tamiya, which is discontinued as well, but you can find some on ebay, the conversion is easy, and you get a 4wd group c car that handles awesome, other then that not seen anything else that works, I hope I am wrong and there is another option, but the wheel base alone is an issue, let alone the low profile body.
zaraz is offline   Reply With Quote
Old 01-28-2017, 05:44 AM   #8
In terms of how much more volume there is between the front wheels, a 787B could be easier as it has a fatter nose.
If I get a shaft driven car, I can easily shorten the drive shaft... Or I'm guessing you can get shorter length drive belts. I can also easily cut and drill my own carbon chassis plates for a shorter wheelbase. Sucks that there is no 'off the shelf' option... but I like a good engineering challenge
However, this one does look a bit crappy though :/
http://www.ebay.com/itm/1-10-Mazda-7...3D142001405595
Old 01-28-2017, 11:32 AM   #9
IAmGreatDane's Avatar
Nissan R390 GT1 is the closest I can think of a Le Mans body on Touring car chassis (TT01):
https://www.tamiyausa.com/items/radi...r390-gt1-58544
Is not a Nissan R88 C, but it's a Nissan?
Best Regards,
I Am GreatDane c'',)
IAmGreatDane is offline   Reply With Quote
Old 01-28-2017, 02:24 PM   #10
Whilst I love all nissans... the aero on that one doesn't seem as aggressive... and perhaps more on par with my GTS zed.
I think perhaps with availability in mind, with the 787B being so popular, that may be my best option.
With regards to shortening the chassis for belt drive cars, you can get shorter belts to spec right? I'm just assuming you can. Failing that I would need to stick with a shaft driven type. As I'm a machinist / mech engineer thats no problem. The only question is what chassis are available with laydown shocks? (Preferably Tamiya)
Old 01-29-2017, 02:50 PM   #11
So it sounds like 'order to length' drive belts dont exist?
So no shaft driven chassis with IFS mods exist? (i'd like to stick with coils over shock)
Or will I have to make one from scratch?
Cheers
Old 01-29-2017, 03:16 PM   #12
howardcano's Avatar
Trader Rating: 35 (100%+)
Cheers
Here is a compilation of drive belts used in various RC cars. You might find one with a suitable length:
http://www.melbrc.org/vB/showpost.ph...52&postcount=1
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-29-2017, 04:17 PM   #13
gigaplex's Avatar
Cheers
I think the Tamiya TB03 had an IFS option, and it's shaft drive.
Old 01-29-2017, 04:56 PM   #14
mailboxck's Avatar
Someone managed to mount a Tamiya GT-R NISMO LMP1 on an Awesomatrix here on RCtech: Nissan Nismo GTR LMP1 Twins
mailboxck is offline   Reply With Quote
Old 01-29-2017, 06:16 PM   #15
tamiya tb03 and tb04 can be made into ifs
