Old 01-25-2017, 03:10 PM   #1
Default Tc gearing
Is there any advantage/disadvantage to 64 pitch gears instead of 48 pitch ?
sgtlt is offline   Reply With Quote
Old 01-25-2017, 03:26 PM   #2
SpeedySST's Avatar
Finer tuning options but a higher possibility of stripping if the mesh isnt right.
Team Durango DETC410 / SpeedPassion / Fantom Racing / Aston Martin Racing
SpeedySST is offline   Reply With Quote
Old 01-25-2017, 03:48 PM   #3
Finer teeth gives you a higher contact ratio (more teeth in contact at a time). This results in a very minor increase in mesh efficiency, maybe .1% at the most. The poster above hit on the main advantage of 64 pitch, you can make finer adjustments to the final drive ratio.
glennhl is offline   Reply With Quote
Old 01-26-2017, 07:43 AM   #4
Thanks for the answers
2013 Pumpkin Classic @ Top Gear Hobbies / Raceway Mohella Northwest Racers 82 10-30-2013 07:42 PM
Drill and tap pinion gear rustlererad3 Electric Off-Road 50 08-22-2012 10:57 AM
Associated gear diff in Losi 22? Maynard Electric Off-Road 57 06-30-2011 07:11 PM
B44.1 Bevel Diff Gear (rear) Oso M Electric Off-Road 13 06-21-2011 08:41 PM
