Like Tree1Likes
Old 01-24-2017, 06:39 PM   #31
DARKSIDE's Avatar
and boom...
http://roarracing.org/4rmb/showthrea...T-W-11-12-2016
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 01-24-2017, 08:39 PM   #32
TOM MAR's Avatar
Originally Posted by DARKSIDE View Post
Naw, already posted that link. lol
But yeah And Boom.
TOM MAR is offline   Reply With Quote
Old 01-25-2017, 02:54 AM   #33
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by TOM MAR View Post
Try this...
I think these should work, they worked for me & I am not a current member.
Tom
Neither worked for me. I'm guessing the problem is on my end, though I haven't the slightest idea why!
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-25-2017, 03:47 AM   #34
massenb203's Avatar
ROAR New Approved motors
http://roarracing.org/4rmb/forumdisp...ec-25-5-Motors
Henry Massenburg
Team C Racing USA, TC10 2015
Ho-B Max RC Park
massenb203 is online now   Reply With Quote
Old 01-25-2017, 04:44 AM   #35
That link is getting a real workout.
djgrom is offline   Reply With Quote
Old 01-25-2017, 06:14 AM   #36
theproffesor's Avatar
Trader Rating: 56 (100%+)
So the question is...
If the minimum resistance spec will keep these new 25.5 motors from doing what the new 21.5 and 17.5 motors have done.
I'm hoping that it does what was intended and keeps the motors on par with each other, not only from one manufacturer to another, but from generation to generation as well.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 01-25-2017, 07:16 AM   #37
howardcano's Avatar
It's a big step in that direction. There are a few other things that should be addressed in the next rules update, but none are as large an influence.
Howard Cano
Old 01-25-2017, 12:54 PM   #38
hotrodchevy14's Avatar
Trader Rating: 106 (100%+)
go with fantom or better
yet motiv
...oh our lady of blessed acceleration, don't fail me now..
sponsored by:Team lint in my pockets racing...
hotrodchevy14 is offline   Reply With Quote
Old 01-25-2017, 01:18 PM   #39
Whatever you get, make sure it has a 12.3 rotor which is the only legal one.
I was looking to buy a new VTA motor recently and I was considering the Hobbywing XeRUN V10, but every online spec I could find (including Hobbywing North America's website) says it only comes with a 12.5 rotor. So that leads me to believe that anybody running one straight out of the box would be illegal. I looked up the rotor part number listed on the ROAR site (http://roarracing.org/4rmb/showthrea...101-05-31-2016) and it says it is a 12.5 rotor.
The other Hobbywing motor on the approved list (Just Stock 3650) appears to come with a 12.3 rotor only which would make it legal. However, it has fixed timing which I think would make it useless for racing.
microed is offline   Reply With Quote
Old 01-25-2017, 02:08 PM   #40
Originally Posted by jlfx car audio View Post
All this is true . But the one veritable companies can do is improve on rotor strength .. the Novak rotors are old technology 1200-1300ish rotors (12.3mm)
Newer motor are using new processed to get motors in the 1750 range motiv (12.5mm)
Only other rotors that come close is the TSR @ 1650ish (12.5mm)
So given this info I would be looking at TSR/motiv for their new style motors bacause there new can design is much lighter and rotor strength is much higher than other brands at the moment ... That's why those 2 companies would be my first choice
Most of the rotor testers I've seen (including the one I built) place the rotor in "V" blocks a fixed distance from the sensor. The 12.5 rotor will read as stronger simply because it is closer to the sensor. It may not actually be better magnetic material (and they're illegal anyway in VTA).
Kevin Marcy is offline   Reply With Quote
Old 01-25-2017, 02:22 PM   #41
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
i agree they do read higher but a normal 12.5 rotor reads 1400ish but the newer tsr,motiv are 1640-1750
apply that same tech to the 12.3 rotor and your looking at a 1400+ 12.3 and thats just guessing .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-25-2017, 02:26 PM   #42
Kregger's Avatar
I asked because the OP was asking about the D4.
Unless I read it wrong the D4 25.5 is being listed as roar approved.
Kregger is offline   Reply With Quote
Old 01-25-2017, 03:02 PM   #43
Definitely not ROAR approved. The 24k is though.
-Mike B.
Carnage9270 is online now   Reply With Quote
Old 01-25-2017, 03:11 PM   #44
There's no new technology to applying a magnetic charge to magnetic material. What is changed is how much magnetic material is present. This gives the torque you are referring to. Mod rotors use more magnetic material than a stock rotor, that's why the gauss rating is so high. The reason TS and Motiv are using such high gauss rotors is because of the way the stator is made. They are extremely high rpm stators, this needs to be compensated with a really high gauss rotor. The combination works well, but it's not applicable to a 25.5 quite the same way. A 25.5 stator is far from an "RPM" stator like the short stacks.
The only way to increase the gauss rating on a 12.3 rotor is to increase the length of the magnetic material. But roar defines how long that can be (25 to 26mm) as well as the diameter (12.3). So there's not much wiggle room in the rotor department. Like I said earlier, it all comes down to how close to the legal limit the stator is. And frankly speaking, at 101 pole to pole, unless a motor is way off (like 120) you won't notice a whole lot on a 25.5.
The true measure of a 25.5 at this point, at least for me, is material quality. (stator material, wire material, sensor units, case etc). This is where I see a huge difference between manufacturers.
-Mike B.
Old 01-25-2017, 04:40 PM   #45
I guess 25.5t motors will be getting alot of attention from now on, but wouldn't it be better to gain power by reducing the car's rotational mass instead ???
bertrandsv87 is offline   Reply With Quote
U.S. Vintage Trans-Am Racing Part 2 IBLib Electric On-Road 10715 Today 01:25 PM
Novak Havoc 2S with Trinity Monster Locked? Delawareguy Electric On-Road 6 12-05-2011 01:59 PM
