Like Tree1Likes
Old 01-24-2017, 11:57 AM   #16
TOM MAR's Avatar
http://roarracing.org/4rmb/forumdisplay.php?23-Motor-Approvals
TOM MAR is online now   Reply With Quote
Old 01-24-2017, 12:10 PM   #17
howardcano's Avatar
Trader Rating: 35 (100%+)
That doesn't seem to be a public forum.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-24-2017, 01:03 PM   #18
http://www.roarracing.com/approved_brushless_motors.php
Just type 25.5 in the search box
Serzoni is offline   Reply With Quote
Old 01-24-2017, 01:20 PM   #19
TOM MAR's Avatar
Try this...
http://roarracing.org/4rmb/showthrea...T-W-11-12-2016
I think these should work, they worked for me & I am not a current member.
Tom
Old 01-24-2017, 01:25 PM   #20
DARKSIDE's Avatar
http://roarracing.org/4rmb/forumdisp...ec-25-5-Motors
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 01-24-2017, 02:06 PM   #21
trf415msx's Avatar
Trader Rating: 14 (100%+)
Fantom is list on ROAR with 17.5 motor list
trf415msx is offline   Reply With Quote
Old 01-24-2017, 02:27 PM   #22
There's not much that can be done with the new 25.5 motor specs. It defines minimum IR, stator length, type of wind...everything. They will all be very similar in performance. Only thing you can hope for is to buy an old Novak and hope you get one that is outside the parameters of the new stated spec as those motors weren't monitored but are grandfathered. The only thing motor manufacturers can do at this point is try to push the envelope and make motors right at the 101 milliohm cutoff. Dangerous to do as a production run causes variations that can make a motor illegal right off the production floor if they build it too close.
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 01-24-2017, 04:06 PM   #23
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
All this is true . But the one veritable companies can do is improve on rotor strength .. the Novak rotors are old technology 1200-1300ish rotors (12.3mm)
Newer motor are using new processed to get motors in the 1750 range motiv (12.5mm)
Only other rotors that come close is the TSR @ 1650ish (12.5mm)
So given this info I would be looking at TSR/motiv for their new style motors bacause there new can design is much lighter and rotor strength is much higher than other brands at the moment ... That's why those 2 companies would be my first choice
jlfx car audio is offline   Reply With Quote
Old 01-24-2017, 05:41 PM   #24
Kregger's Avatar
Am I missing something because I don't see the D4 on the list.
Kregger is offline   Reply With Quote
Old 01-24-2017, 05:48 PM   #25
gigaplex's Avatar
Rotor strength gives more torque but loses out on RPM. It's not always faster.
gigaplex is online now   Reply With Quote
Old 01-24-2017, 05:51 PM   #26
isn't that what gear choices are for.
freebird is offline   Reply With Quote
Old 01-24-2017, 06:24 PM   #27
TOM MAR's Avatar
Probably not submitted, like the D3.5.
Old 01-24-2017, 06:26 PM   #28
DARKSIDE's Avatar
only the 24k is legal
http://roarracing.org/4rmb/showthrea...804-05-13-2016
Old 01-24-2017, 06:29 PM   #29
Higher #s on rotors have always giving me more efficient motors that run cooler and more consistent
Old 01-24-2017, 06:35 PM   #30
1/4milecrazy's Avatar
D4 is not on the list.
Motiv
Maclan
Trinity 24K
Hobbywing
Fantom
Team Scream
Tekin Gen 3
All must have 12.3 rotor. List gives the part numbers for approved motors. I am undecided right now between the Fantom, Motiv or the Maclan. I have seen a couple reliability issues with TSR motors. Maclan is probably a bit slower but runs super cool and is also the cheapest. VERY happy with my Maclan 17.5.
http://www.roarracing.com/approvals/...lessmotors.php
1/4milecrazy is offline   Reply With Quote
U.S. Vintage Trans-Am Racing Part 2 IBLib Electric On-Road 10709 Yesterday 08:53 AM
Novak Havoc 2S with Trinity Monster Locked? Delawareguy Electric On-Road 6 12-05-2011 01:59 PM
