Old 01-23-2017, 11:20 AM   #46
Chris Adams's Avatar
I really dont care if its rocket or qual at this point. Looking back over the last year, if it had been qual points, I wouldn't have won Nationals as I tq'd the event on the last qual, but I would of TQ'd the Halloween race. There is a plus and minus for either.
Triple A mains is something I would like to see more than a change in format even if its 4 min A mains to compensate for the extra time.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2017!
Chris Adams is offline   Reply With Quote
Old 01-23-2017, 12:10 PM   #47
MontanaMaxx's Avatar
Originally Posted by Race19s View Post
If you're going to a race for multiple days, are you happy that only 1 race and the main matter? If you're the fastest MF'r in the building, why cant you back up that fastest Rocket round?
Exactly and makes a guy earn the spot and not get lucky one round i mean if your truly that good to be on top why can't you do it more than once? And I believe it better evens the field on skill level because it's a resort each round have good run move up with faster guys the top of the field is usually the same guys no matter what format is used
MontanaMaxx is offline   Reply With Quote
Old 01-23-2017, 12:17 PM   #48
Originally Posted by chensleyrc1 View Post
If qual points are so great, then why is there a throw out? If you really want qual points, all rounds should count or throw the best AND worst runs out. This throwing out of a bad round does away with the qual point philosophy and in my opinion "consistency" has not been rewarded. In the end, I race and accept whatever the director says, lol.
Throwing out one in the case of using first random sort as seeding only makes sense as you may have been unlucky to get in a heat of lower main drivers and not get a solid good run also if you happen to break and miss on round like I did you will still end up within a few spots instead of the bottom it's essentially like having a six race series and dropping one race for end result allows you to not drop to the bottom because you couldn't make one race
Old 01-23-2017, 01:29 PM   #49
Trader Rating: 30 (100%+)
Im not saying they are the greatest, or that they worst. Simply stating that If you're the fastest guy at a race, having to lay 1 more round down shouldn't be so hard.
CRC WGT SE-CRC WC 12th 17.5-CRC WC 12th 13.5
LSRCC.COM genesisrcraceway.com/
Race19s is offline   Reply With Quote
Old 01-23-2017, 02:22 PM   #50
RBLove's Avatar
Trader Rating: 72 (100%+)
Qual points worked great at this race. The crew did a good job all weekend and the racing was excellent.
RBLove is offline   Reply With Quote
Old 01-23-2017, 02:49 PM   #51
Everyone got faster as the weekend went on. Some more then others. Be it car prep or track conditions or both. But the fastest in each class rose to the top, qual points or not.
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 01-23-2017, 03:38 PM   #52
hanulec's Avatar
Trader Rating: 27 (100%+)
4m mains! yes! 1-2m less for me to blow out in!
combine qual points + shorter races + more mains + (my add) lower voltage == racing great again
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-23-2017, 05:27 PM   #53
Trader Rating: 21 (100%+)
"In order to finish first, you must first finish"
I'm thinking qualification should be based fastest LAST lap. That way it really eliminates the need for consistency and also eliminates the whole rocket round situation.
It also eliminates the motor and battery wars....The initial hot laps generated by over peaking or this weeks hot motor are somewhat nullified after 5-8 minutes.
Also, you cant run one hot lap and blow out 2 minutes in - you do have to finish the heat. Then whoever has the fastest last lap is TQ.
Sir Loin is offline   Reply With Quote
Old 01-24-2017, 02:26 PM   #54
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
First and foremost someone said ETS is not qual points. I have been watching it since day 1. Every race is qual points.
now to address the quote above. Bad day to lay off huffing glue?
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 01-24-2017, 02:54 PM   #55
Racermac73's Avatar
Lol, Larry needs to post more.. im in favor of qual points since it upsets Cheng and he stays home in protest
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Old 01-24-2017, 04:09 PM   #56
Eric Swanson's Avatar
When was the last time you looked at the results of a qual-points race and thought to yourself "Damn, that guy has NO business being in the main!"
Never. Because with qual-points, you have two variables in which one must be competent to rise to the top, not just one. You have to be fast and consistent.
Now, how many times can you think of where you are out-qualified by some guy you know you are faster than because they performed better than you in the magical mystery round? I'd render a guess that we have all experienced this at least a handful of times.
Therefore, if you weigh the pros and cons, you really can't make an argument against qual-points that is based on the skill or worthiness of a competitor who is in the A-main. Will there be some dudes worthy of being in it who miss out? Yeah, absolutely. There always are regardless of qualifying format. But will there be someone who sneaks in by chance who doesn't belong? No. Never.
You can argue that qual-points are more confusing or they cause less spectacular driving, but at the end of the day we are trying to measure one's ability to perform throughout a race program. If your track stays the same throughout the event, great; run rocket round. But if there is even the slightest bit of deviation, it should be qual-points every time. Otherwise, why even have a multi-day event? You might as well have a day of open practice and whoever turns the fastest single lap is declared the victor.
In the para-phrased words of Sebastian Vettel: "Honestly! What are we doing here? Racing? Or rolling dice in a rocket round?"
Team Associated | Reedy Power | AKA | Schelle | LiveRC | LiveTime
Eric Swanson is offline   Reply With Quote
Old 01-24-2017, 04:11 PM   #57
Last edited by Eric Swanson; 01-24-2017 at 04:12 PM. Reason: Forgot how to computer.
Old 01-24-2017, 04:38 PM   #58
gigaplex's Avatar
You may as well just require batteries to only be charged to 7.8V and the competitor only does a single lap, if the only lap that is measured is their last lap. You'd just get a bunch of people driving slow for most of the 'race' to conserve batteries, tires and temps if they knew only their last lap counted.
gigaplex is offline   Reply With Quote
Old 01-24-2017, 05:53 PM   #59
This could actually benefit your mentioned driving style, since you claim to blow out a lot. Basically, you would cruise around for some time finding your line and warming up, then ramp up to your final lap. Very relaxed, enjoyable way to spend a few minutes followed by a crescendo to frantic pace final lap.
its pretty much a nascar and F1 model for qualifying..
Last edited by Sir Loin; 01-24-2017 at 05:57 PM. Reason: bad day to lay off huffing CA
Old 01-24-2017, 05:55 PM   #60
All good points to consider in our new qualifying methodology. Do you think there is a good way to prevent these or solve them up front?
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3140 07-24-2017 06:43 PM
2012 U.S. VTA+ SOUTHERN NATIONALS in MUSIC CITY, U.S.A. DARKSIDE Electric On-Road 884 09-16-2013 06:43 AM
R.O.A.R. On-Road Regional Race. Nov. 4th & 5th @ S.I.R. rchoudini Northwest Racers 227 11-07-2006 08:27 PM
