Old 01-19-2017, 09:35 PM   #1
Default Diff classes for Touring
I failed to find a single writeup that talks about the definition of different classes for 1:10 190mm touring.
Can someone please help?
E.g., Blinky, Superstock, Blinky Superstock? Then there is Modified right?
Can someone please help differentiate the above for me? Thanks!
SoLost is offline   Reply With Quote
Old 01-20-2017, 12:02 AM   #2
It's really very simple:
Blinky - zero-boost mode on the ESC (shown by a blinking led in neutral) = no timing on the esc
Boosted - timing on the ESC is allowed
Stock - motor is limited to a certain wind, usually a 17,5t
Superstock - just a fancy name for stock with a more powerful motor e.g. a 13,5t or 10,5t
Modified - no limits on either ESC or motor power or timing other than the motor size
Blinky superstock than would be something like 13,5t motors with no esc timing allowed.
Last edited by perzeus; 01-20-2017 at 01:20 AM. Reason: mistake in the last sentence
perzeus is offline   Reply With Quote
Old 01-20-2017, 12:15 AM   #3
Thank you so much.
The only one that I do not understand is Blink Superstock. If Blinky is no ESC boost, Superstock is say 13.5T, then why would Blinky Superstock - 13.5T with ESC TIming?
Do you gear say Boosted and Blinky the same way?
Old 01-20-2017, 01:19 AM   #4
Ups, sorry, my fault, I mixed up that last sentence
I will edit that...
Old 01-20-2017, 01:25 AM   #5
Sometimes there is a prescribed gearing for stock in the rules. Usually a lowest Final Drive Ratio than you can use.
If not prescribed you typically would use a slightly higher FDR (smaller pinion) in boosted than in blinky.
Old 01-20-2017, 05:38 AM   #6
If you're talking about the United States there is basically 4 classes right now (5 if you count 13.5 blinky, but there is less and less of that being run)
Vta is 25.5 blinky, 1450 grams, spec tires, spec body list
Usgt is 21.5 blinky, 1380 grams, spec tires, spec body list
stock touring car is 17.5 blinky, 1350 grams, possible spec tire per event
mod touring car is open motor with boost allowed, 1350 grams, possible spec tire per event
anr211 is offline   Reply With Quote
Old 01-20-2017, 09:12 AM   #7
I will edit that...
Thanks! All clear now!
Old 01-20-2017, 09:12 AM   #8
Thank you everyone for your replies. It gets confusing for a newbie... well I am not a newbie but have been away for many years, finally returning to this great hobby!
2014/2015 ALBERTA TOURING SERIES (ATS) BoneCrusher Canadian R/C Scene 133 02-24-2015 08:22 PM
MRCC EP 1/10 Touring and Drift Indoor Carpet Championship - Miri,Sarawak BRC Malaysian R/C Racers 31 11-25-2011 04:29 PM
MRCC EP 1/10 Touring and Drift Indoor Carpet Championship - Miri BRC Brunei R/C Racers 30 11-24-2011 07:32 AM
Boarderline west chester on road racing orangewhite710 Racing Forum 563 10-03-2007 01:09 PM
