Old 01-19-2017, 01:03 PM   #1
Default What is cogging?
What causes a brushless electric car to cogg and what do you need to do to correct this problem??
nitrohead5300 is offline   Reply With Quote
Old 01-19-2017, 02:08 PM   #2
massenb203's Avatar
Motor cogging is when the motor hesitate once the throttle trigger is press due to it's inability to rotate due to improper gearing or lack power from a low C Rating battery.
Cogging from Battery: Get a higher C Rated battery that matches your motor Amps.
Cogging from Gearing: Reduce your pinion size until the motor is able to create enough torque to turn without hesitation when the throttle trigger is pulled.
Henry Massenburg
Team C Racing USA, TC10 2015
Ho-B Max RC Park
massenb203 is offline   Reply With Quote
Old 01-19-2017, 02:11 PM   #3
big_ads's Avatar
Trader Rating: 78 (100%+)
Send a message via MSN to big_ads
If it is a sensored system it could mean the sensor board on the motor, sensor cable, or sensor port on the speed control have a malfunction.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Protoform/Pro-line - Team Genesis R/C Products - Big Head Racing - Team PRCP
big_ads is offline   Reply With Quote
Old 01-19-2017, 03:31 PM   #4
eR1c's Avatar
i'll add one more item related to motor torque and gearing.
If you've turned your motor timing up too high you can also experience cogging (especially if your just at the edge of using the highest pinion and spur gears for your setup).
eR1c is offline   Reply With Quote
Old 01-20-2017, 05:24 AM   #5
Thanks for your advice gentlemen.
Old 01-20-2017, 09:59 AM   #6
Zerodefect's Avatar
It's when the ESC is firing to the wrong phase of the stator causing the motor to surge and stop, before going well.
Usually a bad sensor, over geared, weak battery etc. etc. The motor will also get very, very hot quickly, if you continue racing with cogging.
Zerodefect is offline   Reply With Quote
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
e-maxx with vxl system and 3s lipo streetracer745 Monster Trucks 50 06-12-2011 07:00 PM
What makes a brushless motor cog ? SteveJa Electric Off-Road 13 08-10-2006 11:18 PM
