CRC WTF1 FC16 Front End Assembly Question
I'm currently building my kit and I am working on the from end. When I add the two white shims to the post for the front axle, I'm not able to screw the housing on on both the left and the right knuckles. Am I supposed to use both White shims or am i missing something on the assembly?
On the kingpin, those shims can be used to adjust ride height, droop and spring preload. With the battery in the rear of the car and with the kit .45mm springs, both spacers go between the knuckle and the lower arm. With the battery full forward I move one shim to between the spring end and the eclip to raise the front end ride height. Fine tuning can be done by adjusting the length of the kingpin. Be sure to start with them the same length from the knuckle.
I have mine setting on their bottom with the links swept forward in the center. I used taller ball studs so that the steering link angle matched the upper arm angle. It took 3/8" tall ones on the steering knuckle and 1/2" tall ones on the servo saver with the servo I ran. I just switched to a Solar 658 which is a standard mini size and the ball studs on the servo are now 3/8".
what bodies will fit on this?
https://www.amainhobbies.com/bittyde...f1-t6c/p492950
this is the one I ordered, hope it works I emailed CRC to ask which one they recommended and got no response, hope this is not a sign of things to come if I need customer support.
Not sure who you emailed, but if anyone needs anything, feel free to email [email protected] or just pick up the phone and call (315)-338-0867.
Brian Wynn
Team CRC
Brian Wynn
Team CRC
Ok got my kit and built it last night went pretty good, First time building a car like this was a new experience. now I need to figure out what servo works all mine seem to be to wide to fit in between the sandwich plates. can someone point me towards a good servo for this that will not break the bank. And can someone post pics of the front wing mounting, does it just use one bolt? and has anyone mounted a fan on this looking for ideas. The wings I got are the protoform ones.
The front long bold goes through the wing, so yes a one bolt mount. Some wings need a light trim to fit.
I have fitted a fan before but not for a while. Used a 2nd motor mount on the non-diff side and secured the fan to that with a long bolt and nyloc nut.
Some others I have seen fun a fan mounted over the motor. Don't have a photo of that (sorry!)
Hope that helps
Mark
