Old 01-11-2017, 02:45 PM   #1
Default Charging 2s LRP lipo
I have the 5800 stock spec lipos
whats the best amperage to charge these at.
andrew
andrew19 is offline   Reply With Quote
Old 01-11-2017, 05:19 PM   #2
Skiddins's Avatar
The recommended is 1C, so 5.8A
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-11-2017, 05:26 PM   #3
Trader Rating: 17 (100%+)
+1 1C is the safest to make your battery's last
T_Lee is offline   Reply With Quote
Old 01-11-2017, 11:31 PM   #4
I have had a look at the data sheet for the lipo and they say 12a
Old 01-12-2017, 01:39 AM   #5
Skiddins's Avatar
Looks like you've found your max charging current then, just over 2C (twice the 'C'apacity)
Bare in the mind the quicker you charge them the more you'll reduce their lifespan.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-12-2017, 01:52 AM   #6
He's right, it says in the manual the recommended charge current is 12A, the max charging current is 3C. But I stick to 5.8A unless I need to charge the battery quickly, and even then I never go above 10A. My batteries are still competitive after a year of heavy use.
perzeus is offline   Reply With Quote
Old 01-12-2017, 04:04 AM   #7
Cheers
so really its more about how fast you want to charge and how long you want them to last.
so by making sure they are balanced and and charged at 5.8 you will still get the same performance as if charging at 12a
Old 01-12-2017, 04:10 AM   #8
All of the above is true. Just make sure you balance charge them on a balancing charger, not an add on card.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 01-12-2017, 04:52 AM   #9
I tried test charging these batteries at 20 A, but could not see any performance difference, either on track or when comparing the discharge curves using 10A discharge current.
LRP VTEC LiPo batteries rcforum Electric On-Road 26 09-03-2015 07:54 PM
Charging LRP Lipo(79980) for M11? JL Radio and Electronics 8 07-22-2008 12:40 PM
