Old 01-08-2017, 11:57 AM   #1
Default Reaktor Charger Problems
Hi
I have got a realtor charger and seem to be having problems charging a 2s lipo
it keeps say that the balance port not connected when it is when i try and balance charge and when i try a discharge it says the cel voltage is to low
any help
andrew19 is offline   Reply With Quote
Old 01-08-2017, 02:57 PM   #2
Trader Rating: 44 (100%+)
Does it do it with just one battery or have you tried different batteries and have the same issue?
biz77 is offline   Reply With Quote
Old 01-08-2017, 07:48 PM   #3
robk's Avatar
Trader Rating: 22 (100%+)
Check your charge cable. If one of the small balance port wires is frayed or broken you will get this message.
Old 01-08-2017, 10:25 PM   #4
Hi
I works fine on normal charge just when I do balance charging both packs of lipos are the same and the charge lead works well on another charger so do the lipos
Old 01-09-2017, 11:21 AM   #5
Sounds like a balance port issue on the charger if you have two batteries experiencing the same issue and it's not an issue with those batteries on other chargers.
Old 01-09-2017, 06:08 PM   #6
I had this issue and it turned out the small lead on my charge cable was making intermittent connections. Resoldered it and now everything works.
glennhl is offline   Reply With Quote
Modding a Hewlett Packard 750 Watt Power Supply platgof Radio and Electronics 45 11-10-2016 05:55 PM
turnigy reaktor lipo charger genel R/C Items: For Sale/Trade 10 08-03-2016 02:15 PM
Discharging at 30-40 Amps - Stand alone discharger JAE Radio and Electronics 26 04-10-2016 04:22 PM
HP DPS 600 PB Mod platgof Radio and Electronics 9 03-12-2016 09:21 PM
Dependable First LiPo Charger Recs. twinrider1 Radio and Electronics 23 11-11-2014 08:40 PM
