Like Tree20Likes
Old 04-04-2017, 08:06 AM   #76
My brother and I are still slowly recovering from the diff/gearbox disaster. Running the TA06 solid steel spool with Tamiya driveshafts and FF03 gears finally got the chassis to a race worthy state but corner entry speed/steering was terrible. The car was fast but on our tight track top speed has little value. This week we'll try the TA06 steel bevel gear diff - starting with light diff oil (1000cst) as a learning exercise. If we can carry some speed through the corner then the we won't have to rely on maximum pull out of the corners.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is offline   Reply With Quote
Old 04-06-2017, 01:18 PM   #77
Trader Rating: 4 (83%+)
The VBC deliver the power right at the right place and if you run the geardiff too hard you will be moore slow than a midle or soft diff... in my diff I have 2.5M gravity silicone and when I will do the rebuilt I will test 300 000cst and 500 000cst like the manual said
Xray T4 2017
Yokomo BD7 2015 Spice FWD
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Quinny45 is offline   Reply With Quote
Old 04-06-2017, 01:34 PM   #78
I built the original diffs in both cars with 500,000cst as per the manual but the bevel gears skipped so bad I couldn't evaluate the performance.
Old 04-06-2017, 03:19 PM   #79
Trader Rating: 50 (100%+)
you can order this D-06-VBC-0237 and replace the original gear, I have the same problem before but it fix now.
https://www.vbcracing.com/products/m...-d-06-vbc-0237
Quinny45 likes this.
Kyosho MP9 TKI 4 / OS B2101 / Ko Propo
Xray T4 2017 / HobbyWing / Sanwa
Mts FF V2 / HobbyWing / Sanwa
teddymp9 is offline   Reply With Quote
Old 04-06-2017, 05:35 PM   #80
It would be nice not to have to throw out this big beautiful hunk of machined aluminum.
Old 04-06-2017, 06:26 PM   #81
if the gear skip you just need to remove the paper gasket !
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 04-06-2017, 07:00 PM   #82
fyrstormer's Avatar
If you remove the paper gasket, the diff won't seal properly anymore. Add shims behind the gears to take up the extra space so they mesh properly.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 04-07-2017, 04:34 AM   #83
my diff dont leak with 2.5M inside but you are right with the shims if you run a softer diff
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 04-07-2017, 08:24 AM   #84
I did remove the gasket on the 500,000 cst build but it was too late. I'll get some of the steel gear sets and re-shim but you still need Tamiya idler and top gears. I want the belt drive but all the parts needed are not available it seems.
Old 04-28-2017, 07:45 AM   #85
Trader Rating: 27 (100%+)
https://www.vbcracing.com/collection...-d-05-vbc-0271
aracefan likes this.
Awesomatix-Vbc-Hudy-Orca-motiv-Tsr-
pat5b is offline   Reply With Quote
Old 04-28-2017, 07:11 PM   #86
woohoo !!!!
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 05-11-2017, 09:39 AM   #87
aracefan's Avatar
Trader Rating: 38 (100%+)
Just ordered a new FF17!! Got it for $209 shipped!
Think I may go ahead and order the FFTwelve belt conversion for it. After reading through the thread and some of the issues people are having with the steel gears I think it may be best to just start with the belt drive.
Can't wait to get this in and build it.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 05-11-2017, 11:10 AM   #88
Just let you know when you order the Belt Conversion kit by VBC, just made sure to order the BELT TENSIONER set, if not, your belt will be very loose.
Old 05-11-2017, 12:04 PM   #89
aracefan's Avatar
Thanks for the tip Teddy. I think I have one on my FFTwelve, I'll probably go ahead and order one anyway.
Old 05-11-2017, 01:36 PM   #90
aracefan's Avatar
I think I just looked at every single part on VBC site and can't find the belt tensioner anywhere on there. You have a link or part number?? TIA.
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
