Old 01-03-2017, 05:28 AM   #1
Default setup
been fighting off power push car not rotating having to wait for the car to turn t4-16 what direction to look at
to slow for you is offline   Reply With Quote
Old 01-03-2017, 05:33 AM   #2
Loco4G63T's Avatar
Trader Rating: 23 (100%+)
Best sites and resources to explain how to tune your chassis......
Check this out and hopefully it will give you a few ideas to try.
"D" TTRC - RCRNV and Mimi's "The TRACK".
OFF ROAD - B5M CE, TLR22T 2.0, and Mugen MBX7R Eco.
ON ROAD - 13' T4(VTA), 14' T4(USGT), CRC X10LE (WGT), Tamiya M03-R & Euro Semi-Truck, MST FXX-D S II (DRIFT) and Serpent 977e Evo 2.
Driving through hell and back! Phoenix Raceway, Afghanistan 10'-11'.
Loco4G63T is offline   Reply With Quote
Old 01-03-2017, 06:31 AM   #3
Trader Rating: 18 (100%+)
could be anything from running a front spool, too thick of rear diff fluid, needing more toe, camber, caster, droop...it's a lot of factors. no one knows where to direct you unless you put up your entire setup
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is offline   Reply With Quote
Old 01-03-2017, 07:53 AM   #4
ok
front droop 6mm
rear droop 5mm
front springs 2.5-2.8
rear springs2.6
shock oil 425 cst frt and rear
front sway bar 1.4
rear bar 1.3
shock locations frt 2hole out
rear shocks location 3 out
left and right balance ok
arm sweep front
rear toe 3.5 in
front toe total 1.5 out
frt spool
rear gear diff 6000cst
camber frt and rear 2.0 -
Old 01-03-2017, 08:02 AM   #5
problem is worse when traction gets high black carpet
Old 01-03-2017, 08:03 AM   #6
Danny-b23's Avatar
Originally Posted by to slow for you View Post
ok
front droop 6mm
rear droop 5mm
rear springs2.6
front sway bar 1.4
rear bar 1.3
arm sweep front
rear toe 3.5 in
frt spool
Not sure what your track looks like, but the first thing I'd do is reduce that rear toe a bit. Maybe just move to the .5 out on the RF blocks. You could also try moving the rear shocks in one hole on the tower and fronts one hole out. That should make the car carve into the corner a bit better.
Pictures of your track and specific corners you're having problems with would also help us sort it out.
EDIT:
Black carpet I would DEFINITELY reduce rear toe. 3.5 is way too much for FT2.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 01-03-2017, 08:07 AM   #7
You didn't say what class, but if we're talking touring car the body also has a large role in entry and exit steering. The ltcr will have more entry steering and the mazda will have more exit steering.
I also think you have way too much rear toe for black carpet, but that doesn't change off power steering as much as it will on power steering.
anr211 is offline   Reply With Quote
Old 01-03-2017, 08:22 AM   #8
ok
front droop 6mm
rear droop 5mm
rear springs2.6
front sway bar 1.4
rear bar 1.3
arm sweep front
rear toe 3.5 in
frt spool
generally i run 5.5 RH front and rear with about 1.5 droop over ride height. your rear diff lube sounds too thick, with some recent reading i went from 7k to 2k. i'm testing it out this weekend, but i could tell it was pushing me on exit.
also as was said above, go to 3* toe in on the rear and i wouldnt go beyond 1* toe out on the front.
ALSO front spools does have a tendency to push as well coming hot into a corner especially off a straight away
Old 01-03-2017, 08:45 AM   #9
thanks i will try some changes
Old 01-03-2017, 09:23 AM   #10
Trader Rating: 16 (100%+)
I don't run an x-ray anymore. But before I got rid of it on ft2 carpet the most rear toe I ever ran was 2.5. and almost always I had 2...
Randleman Offroad RC Driver #1
Triton Engines | Mugen Seiki Racing | Futaba | Fantom Racing
M2C Racing | Vision Racing Products | Nitro Pro Fuel | RC Pit Products
Jwilliams5 is offline   Reply With Quote
Old 01-03-2017, 09:23 AM   #11
Roelof's Avatar
Send a message via ICQ to Roelof
http://forum.teamxray.com/xsheets.php
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Vaterra Twin Hammers Setups? Wickedwolf R/C Crawler Room 11 03-11-2015 06:52 PM
OCRC TRACK SETUP RECOMMENDATIONS clamport Electric Off-Road 17 09-15-2012 02:38 PM
Setup Software for Mobile Phones (Iphone) kiwidave72 Electric On-Road 182 11-28-2011 06:15 PM
Traxxas Slash Setup vstrok Electric Off-Road 20 03-04-2009 09:13 PM
