Like Tree57Likes
Old 03-21-2017, 08:42 AM   #121
OSherman's Avatar
this is the 'grey area' that I think most racers could/should use to their advantage. lube is important to keeping friction areas working properly. its up to the individual how thick that lube could/should be..
$0.02
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-21-2017, 09:47 AM   #122
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Originally Posted by kokoyang View Post
Hello,
This question might be in the same thought/s of previous ones. I am also joining the TCS for Euro Truck and am wondering the following:
1) Can I pack the diff with grease/lube to increase/reduce diff action (front vs. rear)?
2) Can I grease the shock?
...or is "box stock" meaning "manual stock" and we have to build the kit EXACTLY as the manual specifies it?
Thank you! =)
Fred from Tamiya said you can't puddy up the diffs. If you try a grease it ooses out on to the out drives and slows the truck down. I run my diffs dry so the truck is fast as possible
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 03-21-2017, 09:54 AM   #123
So what battery can we run in this at a tcs race the main rules say any roar approved battery and the euro truck rules say Wolfpack
lonslo is offline   Reply With Quote
Old 03-21-2017, 10:11 AM   #124
MD
MD's Avatar
Trader Rating: 118 (100%+)
Where did you see that? Thanks.
MD is offline   Reply With Quote
Old 03-21-2017, 10:20 AM   #125
On the tamiya tcs rules for 2017 it says any roar approved pack can be used for any tcs class. Then under the euro truck class rules it say a reedy round lipo can be used. So can we use any pack or just the reedy.
Old 03-21-2017, 10:39 AM   #126
Trader Rating: 62 (100%+)
Reedy and Peak
sipaboy is offline   Reply With Quote
Old 03-21-2017, 10:41 AM   #127
MD
MD's Avatar
I found the rules on the PDF version. Here's the battery rule.
Batteries: Any Reedy Wolf-Pack or Peak Racing Racing Powermax round-case Lipo battery may be used.
My guess is at a local track or regional TCS race I don't think they will be that picky. But, if you go the nationals they probably will. I have used the Peak battery and it's held well for over a year in a box stock M05 class and you can find them at a reasonable price. I don't know about the Reedy battery.
Old 03-21-2017, 11:35 AM   #128
team green's Avatar
Hello,
Thank you! =)
Yes you can use any grease or oil to pack your diff. But you can not use putty the diff can not be locked. Also you can grease your shocks.
GrandeGixxer likes this.
team green is offline   Reply With Quote
Old 03-21-2017, 03:37 PM   #129
Thank you for all the answers regarding my question about lubing/greasing diffs and/or shocks =)
...now, about tire inserts, (I know this question has been asked...but there wasn't really any definite answers)...so... could we - or could we NOT - use tire inserts?
I'm asking since inserts just lengthen the tire's life...and I would like to save as much as possible =)
...thanks again!
kokoyang is offline   Reply With Quote
Old 03-21-2017, 04:42 PM   #130
team green's Avatar
...thanks again!
No tire inserts or gluing of the sidewalls.
Old 03-21-2017, 04:49 PM   #131
Hello,
Thank you again for the response/s on this...got another question:
Can we install a schottky diode on the "stock" motor as we have always done previously (before brushless motors)?
Thanks! =)
Old 03-21-2017, 05:06 PM   #132
MD
MD's Avatar
Hello,
Thanks! =)
Some ESC's do not work with the diode. I wouldn't add it.
Old 03-21-2017, 05:23 PM   #133
howardcano's Avatar
Trader Rating: 35 (100%+)
Hello,
Thanks! =)
DO NOT use a Schottky diode on an ESC that has reverse.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 03-21-2017, 06:48 PM   #134
Laguna Bozo's Avatar
Finally, team green has the tire answers for those of that are not Rocket Scientists. Thanks.
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 03-27-2017, 09:05 PM   #135
bubbaslash's Avatar
We've been running 2wd CORR for a few years. My oldest son thinks these race rigs would be a fun class to get into. 3 weeks ago, 2 guys showed up with the new kit at a local hobby shop that has an ozite road course. The next week, there were 4 entries. The shop owner now stocks the kits and has sold 6 or 7 more. Eurotruck is now an official class at the track. I think this will be fun and cheap BTW, it sounds like other parts of the country got a jump on us with this new class. Are they running mod versions anywhere?
X-Factory SCX-61....the ultimate multi-surface missile!
Made in USA!
bubbaslash is offline   Reply With Quote
Tamiya GT Pro Spec Class angrymelon Electric On-Road 19 10-22-2017 01:52 PM
tcs in washington subaru73 Northwest Racers 942 10-17-2017 01:01 PM
2016 RC Car World On Road schedule RCCarWorld Mid Atlantic RC Racing 975 09-22-2017 08:00 AM
Tamiya Championship Series 2016 TCS Core Creations Nebraska/Iowa Racing 86 03-12-2016 07:37 PM
