Like Tree25Likes
Old 03-17-2017, 01:09 PM   #106
vivo quevas's Avatar
Trader Rating: 18 (100%+)
the servo saver change was made by Fred before the Fresno Tamiya race
vivo quevas is offline   Reply With Quote
Old 03-17-2017, 01:29 PM   #107
Trader Rating: 16 (100%+)
From TCS General Rules:
"Any manufacturer’s radio equipment, servo saver, antenna pipe, antenna mount, pinion and spur gear, ball bearing, tire insert are allowed in all classes, unless exceptions are noted within class specific rules."
aalewis is offline   Reply With Quote
Old 03-17-2017, 01:30 PM   #108
Laguna Bozo's Avatar
Happy to hear!
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 03-20-2017, 10:21 AM   #109
eR1c's Avatar
Tire insert is allowed?!
Quick question,
I took my Hahn truck out for some practice laps. Overall it drives really well, its stable, etc. However in typical Tamiya "friction damper" fashion the truck has a tendency to hop when coming into hard turns w/ a bit of speed. It doesn't flip or anything, but that hopping is surely going to cost me some time.
Curious what you all are doing to solve this, -given I have to adhere to TCS rules. Was thinking of cutting a bit of my damper springs to lower the ride height and reduce the softness of the dampers? Or maybe use hard Tamiya springs both front and rear? ...yet not sure either of these are legal to do?
eR1c is offline   Reply With Quote
Old 03-20-2017, 10:24 AM   #110
eR1c's Avatar
-Edit, I guess we are not following TCS rules ...ours are even stricter.
Box stock, only change is bearings.
Old 03-20-2017, 10:51 AM   #111
GrandeGixxer's Avatar
I think that as long as you use the stock parts, you could modify springs and such?
GrandeGixxer is offline   Reply With Quote
Old 03-20-2017, 11:58 AM   #112
eR1c's Avatar
thanks,
...do you think cutting the springs a tad would reduce the bounce/hop effect?
Usually a decent pair of shocks alleviates the issue... but not an option!
Old 03-20-2017, 12:04 PM   #113
shmit 1's Avatar
I woild think that cutting the spring down would be illegal for tcs rules. I could be wrong.
shmit 1 is offline   Reply With Quote
Old 03-20-2017, 12:24 PM   #114
eR1c's Avatar
well i'll probably just keep it box stock for now ...first race will be in 2 weeks (got rained out again for the 2nd time)
Old 03-20-2017, 01:25 PM   #115
Default Truck GT
eR1c, yes I think it would help, but as shmit 1 says... likely illegal.
How about that motor cover? Replace with fan?
And then there is the tire insert issue...
I hope some direction will come before TCS race next weekend.
Craig Richter
Old 03-20-2017, 01:41 PM   #116
eR1c's Avatar
HA, the motor cover! i left mine off ...but will be bringing it w/ me and asking at our next race.
Old 03-20-2017, 01:58 PM   #117
OSherman's Avatar
if its not included in the box or written in the manual.....
couple that simple rationale with whats written on the TCS Rules.
this isn't RocketScience
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-20-2017, 02:26 PM   #118
team green's Avatar
When I ran TCS in Fresno. We where told you have to have the motor cover on but you can run a fan. Also no tire inserts or gluing the side walls.
team green is offline   Reply With Quote
Old 03-20-2017, 03:23 PM   #119
eR1c's Avatar
thanks, ...i'll put it back on then.
yeah, I am not running inserts and didn't glue the sidewalls. My kit is literally box stock w/ exception of bearings (which our club said is cool).
Old 03-21-2017, 07:27 AM   #120
Hello,
This question might be in the same thought/s of previous ones. I am also joining the TCS for Euro Truck and am wondering the following:
1) Can I pack the diff with grease/lube to increase/reduce diff action (front vs. rear)?
2) Can I grease the shock?
...or is "box stock" meaning "manual stock" and we have to build the kit EXACTLY as the manual specifies it?
Thank you! =)
kokoyang is offline   Reply With Quote
tcs in washington subaru73 Northwest Racers 937 08-05-2017 11:18 PM
Tamiya GT Pro Spec Class angrymelon Electric On-Road 15 02-17-2017 10:28 AM
2016 RC Car World On Road schedule RCCarWorld Mid Atlantic RC Racing 971 10-14-2016 07:27 AM
Tamiya Championship Series 2016 TCS Core Creations Nebraska/Iowa Racing 86 03-12-2016 06:37 PM
