Like Tree57Likes
Old 07-02-2017, 07:07 AM   #211
MD
MD's Avatar
Trader Rating: 118 (100%+)
Originally Posted by marshallsbbq View Post
Has anyone figured out how to stop all the bouncing. I built my kit per instructions exactly and I been racing with other guys and no bounce. This is supposed to be a spec kit but with all the bouncing it puts me at a disadvantage. I am a whole second slower with all the bouncing.
Kevin
SoCal Eco Cleaning
At our last parking lot race I inserted a piece of file tubing in the front shocks and it helped. It didn't stop the bouncing all together, but it reduced it.
MD is offline   Reply With Quote
Old 07-03-2017, 06:52 AM   #212
SMcD's Avatar
Trader Rating: 61 (100%+)
*opens can of worms*
Is that the black tubing that comes on the motor shaft in packing? Technically, it's in the box, but is it in the instructions to insert the tube into the front shocks?
Driving hours to the Jackson TCS race. I want to know exactly what is legal for that race. I can now see these trucks being torn down to the screw in tech... My truck and I are totally ready for tech. Mine is box stock with grease...
Now, the body - reducing the flex of the cab helps the bounce. I have used shoo goo and nylon screws on the body. Legal???
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 07-03-2017, 07:23 AM   #213
MD
MD's Avatar
I just used some old fuel tubing from an old nitro truck. It may not be legal for the TCS, but I am not running in the TCS. Except for fuel tubing and bearings my truck is box stock. Thanks for the tip on shoo goo.
Old 07-19-2017, 07:31 AM   #214
Send a message via AIM to Nerobro
I got mine built the other day. I'm really quite pleased with how it drives. The corner bouncing is.. charming, but seemingly is controllable with the throttle.
I love the long polar moment of inertia, and how catchable it is in slides.
Nerobro is offline   Reply With Quote
Old 07-19-2017, 09:55 AM   #215
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
TTT
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 07-19-2017, 10:03 AM   #216
MD
MD's Avatar
I have run mine this summer. It's been a lot of fun. The tires have held up very well even though I am running on a rough parking lot.
Old 07-19-2017, 10:33 AM   #217
eR1c's Avatar
..bounce,
I was able to reduce bounce to very minimal by:
1) changing my driving style
2) sanding the inside of the front shocks and outside (so everything is nice and smooth)
3) making sure the entire front suspension assembly is on the looser side, that is loosen all the screws a tad ...nothing should be snug/tight up front.
4) adding weight to the chassis
5) securing the cab of the body so it doesn't flex so much
this is what I did, and works like a charm, I have like 2% bounce now.
Driving style is huge, ...accelerate, then brake on hard turns and coast on long sweeping turns. ..don't throttle it through the turn, only on the turn exit.
SMcD likes this.
eR1c is offline   Reply With Quote
Old 08-29-2017, 11:04 PM   #218
Default How much weight?
Hello,
For those of you adding weights to the chassis, how much weight do you add?
Thanks for the help =)
kokoyang is offline   Reply With Quote
Old 08-30-2017, 09:56 AM   #219
My trouble is mostly rollovers. Bounce is only a problem if I drive like a jerk. Otherwise it's a remarkably stable and controllable setup.
I think the heavy body, and forward CG definitely help.
Now... how to remove the black marks from track gunk.
Old 08-30-2017, 10:19 AM   #220
MD
MD's Avatar
Sometimes Goo Gone will work or motor cleaner.
Old 08-30-2017, 10:23 AM   #221
WD40 works well too
simple is offline   Reply With Quote
Old 08-30-2017, 10:26 AM   #222
I use the orange Goo Gone.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is offline   Reply With Quote
Old 08-30-2017, 11:12 AM   #223
eR1c's Avatar
Hello,
I use about 70 grams of weight total. ...i know its a lot, but has removed the bounce and helps w/ stability/handling.
Try using the weights in various places to suit your needs.
For me:
-about 30grams or so on the battery strap (middle of chassis) ..some put it under the chassis in that cut out area (...actually I have been meaning to move my center weight from the battery to under for even lower center of gravity).
-about 20 grams on rear (at the rear bumper area).
-about 20 grams up front
...but I have moved the weight around a lot ...this seems to be my ideal.
Old 08-30-2017, 11:15 AM   #224
eR1c's Avatar
is this on the body that your talking about? ...another trick i've used (in addition to goo be gone) is "scratch-x" ...it works great on polycarbonate bodies for removing deep marks.
Old 08-30-2017, 11:32 AM   #225
Yeah this is on the body.
the only other thing that bugs me, is that my hitch plate disappeared. I painted it, and now I can't find it.
Tamiya GT Pro Spec Class angrymelon Electric On-Road 19 10-22-2017 01:52 PM
tcs in washington subaru73 Northwest Racers 942 10-17-2017 01:01 PM
2016 RC Car World On Road schedule RCCarWorld Mid Atlantic RC Racing 975 09-22-2017 08:00 AM
Tamiya Championship Series 2016 TCS Core Creations Nebraska/Iowa Racing 86 03-12-2016 07:37 PM
